Heat Wraping JDM ITR Header
Old Nov 23, 2002 | 03:16 PM
ITR607's Avatar
New User
Default Heat Wraping JDM ITR Header
just wondering how many of you guys heat wraped your headers and the pro's and
con's if any?
thanks
Old Nov 23, 2002 | 03:19 PM
BlackDeuceCoupe's Avatar
HT White Ops
Default Re: Heat Wraping JDM ITR Header (ITR607)
http://www.designengineering.com/exhaust_wrap.html
Old Nov 23, 2002 | 03:22 PM
HT White Ops
Oh, BTW, uniformed ppl are going to tell you it'll ruin your header, etc. Prepare to be covered in bullsh!t...
Old Nov 23, 2002 | 03:26 PM
ITR607's Avatar
New User
Default Re: Heat Wraping JDM ITR Header (BlackDeuceCoupe)
i know, but i wanted to see what people using it on honda's think.
Old Nov 23, 2002 | 03:37 PM
HT White Ops
My favorite worm pix; twin turbo:
Not my car, BTW...
Old Nov 23, 2002 | 03:48 PM
dom93hatch's Avatar
Not my car, BTW...
Haha, hey... I posted those pics first on H-T. Hoowah.
Old Nov 23, 2002 | 03:58 PM
HT White Ops
Default Re: Heat Wraping JDM ITR Header (dom93hatch)
We probably got them from the same place. Mine came off some Aussie site. How about yours???
Old Nov 23, 2002 | 03:59 PM
dom93hatch's Avatar
I got those from a deceased Honda board. I knew the car was Aussie too. :D
Old Nov 23, 2002 | 06:25 PM
Mr. Thunderlips's Avatar
In your opinion...Pro's and Con's.
Old Nov 23, 2002 | 06:27 PM
dom93hatch's Avatar
Default Re: Heat Wraping JDM ITR Header (ThunderLips)
Pros: reduces engine bay temp, kinda cool to look at
Cons: I dunno, is it expensive? If you're trying to show off a blingy header maybe you won't want header wrap.
Old Nov 23, 2002 | 09:33 PM
zRd#1's Avatar
anyone got more pics of this car? i likey
Old Nov 23, 2002 | 09:52 PM
-Whitey-'s Avatar
Default Re: Heat Wraping JDM ITR Header (zRd#1)
i think header wrap is good IMO but it does have its cons if you have a bling'n header id not get wrap but if its not bling'n id get it
Old Nov 23, 2002 | 10:20 PM
Default Re: Heat Wraping JDM ITR Header (B16A EH2)
The only reason I ask is because of what BDC mentioned. He said some might consider it a bad thing to do...Just wondering why.
Old Nov 24, 2002 | 01:56 AM
JDMb18civic's Avatar
my header is wrapped...
Old Nov 24, 2002 | 02:36 AM
HT White Ops
I guess you didn't check out the link I furnished above. No, big deal! I do the same thing...
This is from their FAQ section. It'll give you some insights maybe:
Question: Does using Exhaust Wrap on my headers cause premature header failure?
Answer: NO! Over the years, exhaust insulating wrap has received a "bad rap" (no pun intended) and has been attributed to header failure. Studies have shown that properly insulated headers can enjoy an equally long life as their un-wrapped counterparts. As the word circulated that exhaust insulating wrap worked for obtaining lower underhood temperatures and gaining a horsepower advantage, many users got wrapped up (that pun thing again!) into the age long train of thought, which is - "IF A LITTLE IS GOOD, MORE IS BETTER!" This could not be further from the truth.
Excessive overlapping, double wrapping, etc. completely "mummifies" each primary tube, thus decreasing their natural and needed ability to expand and contract as the exhaust heats and cools. Now perhaps you can begin to understand where these half-truth rumors originate.
Question: Why does the Design Engineering Exhaust Wrap have two blue lines stitched in?
Answer: We are the only manufacturer of Exhaust Wrap that provides this time saving guide line. The blue lines are actually wrap indicators which are sewn 1/4" in from the edges of the wrap. This helps act as an overlap guide so you can achieve perfect overlap during installation.
Question: What about year round usage of Exhaust Wrap on my daily driver?
Answer: Good question! As a performance enthusiast, you probably already know that your common mild steel tube headers are prone to "rust rot" with or without the elements - let alone salted, winter roads. We strongly advise the use of our HT Silicone Coating to coat and treat the exhaust wrap after it has been installed. This silicone based, high temperature coating, creates a protective barrier against road grime, oil, dirt and helps prevent water from being wicked up and held against your headers by the wrap.
Question: How do I fasten the wrap to my headers to prevent it from unraveling?
Answer: We manufacture Stainless Steel Locking ties for this purpose. They are neat in appearance and completely constructed of type 304 Stainless Steel. For more info on these ties, click here.
Question: I just installed your Exhaust Wrap and noticed the Wrap smoking after I fired up my vehicle. Is this normal?
Answer: Yes. It should only last a few minutes. What you are actually witnessing is the excess vermiculite "burning" off the wrap. There is no need to be alarmed, just be sure your in a well ventilated area.
Question: I heard that ceramic coatings offer superior thermal retention. I have also heard that Stainless Steel pipes attribute towards sufficient retention as well. If this is true, why would I benefit from wrapping my exhaust with your products?
Answer: While ceramic coatings and Stainless tubing offer good thermal retention properties above and beyond their un-coated and/or mild steel counterparts, coatings and/or Stainless tubing cannot offer as much retention as Exhaust Wrap. Exhaust Wrap offers the highest thermal retention for keeping underhood temperatures down to a minimum. Bar - None!
Questions: What kind of underhood temperature reduction can I expect by wrapping my headers?
Answer: Although our competitors claim 70%, we have tested theirs and ours and have achieved a good average of about 45%.
Old Nov 24, 2002 | 10:06 PM
It's actually because I don't pay attention that well, and navigate sites very well. What I have gathered from that entire paragraph is that wrap reduces underhood temps. Is that what aids in slightly more HP? The lower temps?
Old Nov 24, 2002 | 10:08 PM
Ah...Just saw this... To me for learning how to read.
Horsepower...
Wrapping also increases the thermal retention within pipes and subsequently expedites exhaust flow at a higher velocity. This characteristic increases horsepower.
Although Exhaust Wrap received it's claim to fame from renown engine builders and racers such as the late, great Smokey Yunick, it is not just for racing. Wrapping the exhaust on your RV, heavy duty truck or tow vehicle helps add horsepower while reducing unwanted heat in the engine and driver's compartment. Wrapping the exhaust can also protect surrounding wiring and hoses from premature failure.
Design Engineering's Exhaust Wrap is constructed of a high temp resistant woven fiberglass that is then pre-heat stressed in a process called burnishing. A vermiculite coating is then applied to act as a bonding agent and to increase durability levels under extreme heat - up to 2000º F.
Old Nov 24, 2002 | 10:35 PM
HT White Ops
Ah...Just saw this... To me for learning how to read...
2.0L EK
Dec 18, 2007 02:28 PM
_HANS
Aug 20, 2007 11:17 AM
Teamdiesel
Feb 23, 2006 04:57 PM
Honda_RN
Northern California (Sales)
Feb 9, 2006 07:46 PM
SMSP
Apr 13, 2002 04:49 AM
