I think i'm burning oil... help
i usually notice this: when ever i change my oil... about a week later, a quart of it is gone... where did it go? i normally dont drive hard, except for the occasional open road... TIA...
PS i'm using Mobil 1 Snythetic 5w-30
Ever notice any oil spots when you have your car parked for a while. Get underneath and see if you have any wet spots from oil. Check your spark plugs for oil, too.
synthetic is your first concern...
I used to lose oil too when I was using 5w-30 mobil 1 synthetic, though not as bad as you. I switched to 10w-30 mobil 1 synthetic and the oil loss stopped. just something to consider if you don't need to be using the 5w-30 for winter.
oil loss with mobil 1 seems to be fairly normal.
IMO, you could use a heavier weight oil or if you live in the south you could use a straight weight oil.. or use castrol gtx.
are you sure you are not compensating for the oil that is goin in the oil filter?
Show me a DC2 OEM oil fillter that holds 1qt of oil and I'll get you a ******* from britney spears.
