Eprom question
here is a link to the pinout of the 27c256:
http://www.xs4all.nl/~ganswijk/chipdir/pin/27256.txt
here is a link to the pintout of the 27c512
http://www.xs4all.nl/~ganswijk/chipdir/giicm/27512.txt
as you can see, pin 1 is different depending on which chip you use, so in order to use the 512, you would need to rework the eprom socket...
and here are links to the data sheets for each part:
http://www.mills.edu/ACAD_INFO/MCS/C...s/cy27c256.pdf
http://www.electronicaestudio.com/docs/27c512.pdf
after looking through the data sheets quickly, i wouldn't use the 512 part...
