Integra R Suspension
Old Nov 23, 2002 | 06:19 AM
RoAnSa's Avatar
Default Integra R Suspension
Will Integra R suspension fit on EG???
Old Nov 23, 2002 | 06:54 AM
h82lose2vw's's Avatar
Default Re: Integra R Suspension (RAS612)
the front will but the back need to be modified
Old Nov 23, 2002 | 07:26 AM
Looose_R's Avatar
all of it bolts right on, ALL of it
Old Nov 23, 2002 | 07:34 AM
owen_the_soyboy's Avatar
yes, you need to use the ITR rear lower control arms to use ITR rear shocks. Otherwise all of it bolts up, you will be much better off with ITR front and rear swaybars, lower control arms, shocks and springs... they are far superior to oem civic stuff.
Old Nov 23, 2002 | 10:29 AM
RoAnSa's Avatar
Default Re: Integra R Suspension (owen_the_soyboy)
Will these Control arms fit on my EG????
Old Nov 23, 2002 | 11:18 AM
rainmanEK's Avatar
big strong guy
If they are ITR lower rear control arms then they will fit!!
eric
Old Nov 23, 2002 | 11:21 AM
EK MONEY's Avatar
Default Re: Integra R Suspension (rainmanEK)
need type R rear LCA
Old Nov 23, 2002 | 11:35 AM
ChiBoy's Avatar
Yes, it all bolts up, just like stock. You'll need the ITR rear LCA's and the front's too, if you don't already have a front sway. If you use the ITR rear sway, most people recommend a reinforcing plate similar to the one from Beaks Products. http://www.beaksproducts.com/
The ride is nice and sporty too.
Old Nov 23, 2002 | 12:34 PM
EG6owner-T's Avatar
Default Re: Integra R Suspension (ChiBoy)
so if you have the front and rear itr sway do you still recommend gettin the beaks kit?
for the front sway bar do you need lca or anything else?
o yea check my SIG
Old Nov 23, 2002 | 03:52 PM
chameleon's Avatar
http://www.jdmvtec.com <- step by step how to
all my hard work goes to **** eh!?
Old Nov 24, 2002 | 12:32 AM
EddieHatchBlack's Avatar
Default Re: Integra R Suspension (EG6owner)
yes, the beaks kit helps protect (so far flawlessly) of subframe tearout due to larger sized rear sway bars.
Old Nov 24, 2002 | 07:48 AM
yes! those ITR rear lower control arms (LCA's) are exactly what you need to run ITR rear shocks on your 92-95 Civic (or 94-01 Integra).
[Modified by owen_the_soyboy, 11:52 AM 11/24/2002]
Old Nov 24, 2002 | 07:54 AM
chap99cvc's Avatar
I have the full type r suspension and lca's for $350 shipped. low miles!
Player_One
Suspension & Brakes
Feb 25, 2007 11:55 AM
Wuman
23
Mar 17, 2005 10:50 AM
skribblah
Jul 26, 2003 12:14 PM
bdb
21
Feb 14, 2003 12:42 PM
Mugen_R
Jul 2, 2002 03:43 AM
