Bigger throttle body??
Old Nov 23, 2002 | 05:10 AM
vtecman's Avatar
Default Bigger throttle body??
Is anybody using a larger throttle body on there 99 or 2000 si because I was thinking 0f getting one and i wanted to know if it is worth the money and if they were hard to install on the car?
Old Nov 23, 2002 | 05:14 AM
eg6ajk's Avatar
Default Re: Bigger throttle body?? (vtecman)
what other mods do you have on the car? if no other mods then forget about it. even at best 1-4whp is only gained with those that push 180+whp
Old Nov 23, 2002 | 05:29 AM
vtecman's Avatar
Default Re: Bigger throttle body?? (eg6ajk)
engine wise i have i/h/e and vtec controller
Old Nov 25, 2002 | 12:46 PM
vtecman's Avatar
Default Re: Bigger throttle body?? (George Knighton)
I have the apexi v-afc.
Old Nov 25, 2002 | 01:01 PM
BlackDeuceCoupe's Avatar
HT White Ops
What a throttle body <u>will</u> do is improve throttle response...
Word!
Old Nov 25, 2002 | 02:53 PM
SIReg9's Avatar
Default Re: Bigger throttle body?? (DMS Racing)
Does anyone know what size the factory prelude throttle body is? It looks to me like it can be bolted up on a B-series? And also i was wondering what size is everyone running, i think 70mm is to big, ppl are just all about that cus SPOON makes one.
So if anyone feelslike recomending a size i would apreciate it,
12.2 compression, ITR intake manifold, full valvetrain, CTR cams, VAFC
thanx
Old Nov 25, 2002 | 02:56 PM
Spade's Avatar
Default Re: Bigger throttle body?? (SIReg9)
H22A = 60MM just like the GSR.
Old Nov 25, 2002 | 06:07 PM
HT White Ops
Actually even with 0 mods a larger TB will give you a more responsive pedal. Reason being the there is a larger opening and more air can be inhaled with a lesser throttle Position...
Exactly right! That's a classic definition of 'better throttle response.' Thank you!
Old Nov 25, 2002 | 07:21 PM
customx_'s Avatar
New User
Default Re: Bigger throttle body?? (Spade)
h22a tb is same as itr (62mm)
fg2si!kid
Acura TL, RL & ZDX
Jun 26, 2008 03:57 PM
nitrofish420
Nov 27, 2007 12:52 PM
hmgemperor2003
Sep 16, 2007 10:16 AM
Unsung
May 13, 2003 03:31 AM
CRXRageD
Apr 19, 2002 08:48 AM
