Taking off A/C
Old Nov 22, 2002 | 10:43 PM
Vinceg99's Avatar
Default Taking off A/C
OK I am going to be doing a swap really soon and was thinking I was going to just ditch my A/C (doesnt work anyways) And was wondering with taking out all of the lines and what not what I would have to do?? Or dont it matter? Should I plug the lines?? What about the lines that lead into the blower housing?
Thanks
[Modified by Vinceg99, 1:43 AM 11/23/2002]
Old Nov 22, 2002 | 10:50 PM
marty's Avatar
Default Re: Taking off A/C (Vinceg99)
after you unhook everything you should be ok.
Old Nov 22, 2002 | 10:54 PM
bryant's Avatar
Default Re: Taking off A/C (MugenEF7)
Yeah just watch out for the that freon
Old Nov 22, 2002 | 10:56 PM
marty's Avatar
Default Re: Taking off A/C (CR-X)
for a CRX? you mean stale freon
Old Nov 22, 2002 | 10:57 PM
bryant's Avatar
well if its that old and shoots it out warm, then yes.
Old Nov 22, 2002 | 11:02 PM
marty's Avatar
stale freon owned me
Old Nov 22, 2002 | 11:07 PM
Vinceg99's Avatar
There really isnt even much pressure there.....Some place told me that whoever I bought it from may used some other kind of thing in it?? (not freon) But I guess it has the same affect on cooling as freon but very illegal??
So then I can just unhook the lines and the blower motor (well into the box) open?
[Modified by Vinceg99, 2:08 AM 11/23/2002]
bryant's Avatar
Aww, who needs it, its extra weight
marty's Avatar
exactly
Old Nov 22, 2002 | 11:10 PM
poison's Avatar
exactly
weight reduction and can roll down the windows
Old Nov 22, 2002 | 11:11 PM
marty's Avatar
Default Re: Taking off A/C (poison)
who needs ac? just drive fast with the windows down
Old Nov 22, 2002 | 11:12 PM
Vinceg99's Avatar
So nothing else that I have to worry about then? Just take it all off and go??
Old Nov 22, 2002 | 11:14 PM
marty's Avatar
basically... just watch out for the freon.. dont forget to take out the condensor and all the lines to the firewall.. your all set
Old Nov 22, 2002 | 11:15 PM
bryant's Avatar
couldnt have said it better.
Vinceg99's Avatar
Sweet thanks...not like I have to worry too much about A/C over and up here
Old Nov 22, 2002 | 11:29 PM
uncleben's Avatar
I left the two holes that go into the firewall where the condenser lines went open, I too was wondering if I should plug them with something?
edit: forgot to mention that I decided to be atmosphere-friendly and have
a shop evacuate the freon legally with a machine. it doesn't take any time and only cost me $15. just in case you're worried about the ozone (i'm not really) or something
[Modified by uncleben, 2:32 AM 11/23/2002]
Old Nov 22, 2002 | 11:41 PM
Vinceg99's Avatar
Default Re: Taking off A/C (uncleben)
yeah if you read my earlier post I had stated how a shop said that it might not be freon in there and they didnt even want to try to take it out just incase it was flammable or something?? I might take it somewhere else and see though.
Old Nov 22, 2002 | 11:51 PM
RCautoworks's Avatar
Just use a long screw driver, you will be ok. If you do it yourself make sure you don't get it on your paint. I also left the hole in the fire wall open uncleben.
Old Nov 23, 2002 | 12:59 AM
JwM's Avatar
JwM
Default Re: Taking off A/C (90blackcrx)
I have been considering taking mine out too... I have an 88 HF, and I dunno if I will just wait till I swap it or what, but it can't be too complicated lol... Famous last words, but owell... I will prolly take it as well and have them discharge it...
Old Nov 23, 2002 | 03:22 AM
jc836's Avatar
Default Re: Taking off A/C (MayonakaNinja)
This project is so simple I can do it with only 3 wrenches and a Schrader valve tool for the FREON. Legally you are supposed to have a pro take the FREON out, but some people just release it from a cracked fitting or pipe. BTW: The parts are actually worth a good bit-I sold mine easily on one of the boards (compressor and bracket are worth $90).
You will need to either find a donor car without AC or buy the 2 grommets from the dealer. These 2 are required-one for the hoses and the other for the drain tube. Another thing, you have a choice on whether you take the evaporator case out or not (I did)-if you have a non-AC donor you can get the connector tube that goes between the blower and the heater box to replace the case.
Now to take apart time: Take the AC fan out and find the wiring harness. You want to save all of the pieces including the part that goes thru the firewall and the relays.
Now that there is NO freon in the system you can disconnect the fittings on the pipes. 1 pipe runs in front of the radiator and you will want to move the rad out of the way-you can either drain it and take it off its hoses and get it completely out or just gently tilt it back after taking the core support and hood latch support out - so that you can lift the condensor out. Be sure to save ALL of the O-rings and hardware. The Belt adjuster is a fun item-you put a wrench on the pulley bolt and loosen it then crank down the adjuster so that you can take the belt off. Then you take the 4 mounting bolts off the compressor and after that you can remove the bracket.
To work under the dash-remove the glove boxand the metal bracket going across. You will find the retaining hardware on the evaporator case easily enough and with it sitting on the floor you will find the wiring harness connections that you need toget at. If you decide NOtT to get the grommets and duct piece (bad idea in my opinion)tape up the tubes coming out of the housing and reinstall the case. Why do I recommend this-you can get a lot just for this part if in excellent condition. The duct may be available at a dealer-some keep these things lying around.
Hope this is a good overview for you. Takes about 2 hours to do it right the first time. Helm will be very useful or a printout from the dealer of parts locations.
Good luck and have a happy holiday
Difficulty scale:
Old Nov 23, 2002 | 09:43 AM
Vinceg99's Avatar
Default Re: Taking off A/C (jc836)
What are the gromments that your talking about? Just something to plug the holes? And also the duct piece that runs between the blower and heater boxes what happens if you dont ge this? And how hard is it to put in? Will I need to completely replace the blower box from a non-a/c car? Thanks for your input so far.......
I CRX I
Dec 27, 2006 06:40 PM
the-pepsi-man
30
Feb 19, 2005 12:57 PM
CBXweb
29
Feb 21, 2004 09:42 AM
yoshi234
Jul 25, 2002 04:16 PM
Eyewitness
25
Jul 16, 2002 11:29 AM
