Check Engine Light?
Old Nov 22, 2002 | 10:42 PM
SamC's Avatar
Default Check Engine Light?
I unplugged the VAFC at the connector for security reason while parking outside. After I reconnect the VAFC and start the car, the check engine light came on. What I did was turn off the car, reconnect the VAFC, and disconnect the battery for a second or so. When I turn the igntion, the check engine light is gone. Is this check engine light something I need to worry about? was is just a bad connection?...I'm just paranoid since this is my first check engine light. Thanks guys
Old Nov 22, 2002 | 10:44 PM
sgT's Avatar
sgT
Default Re: Check Engine Light? (SamC)
i would only worry about it if it comes back.
Old Nov 23, 2002 | 02:42 AM
1slowassr's Avatar
Default Re: Check Engine Light? (sgT)
check engine light alot of times dosent mean ****, well it does mean something but it can be pointless like mine was, my fieldsm vtec controller used to make mine come on and it was ****** with the map sensor which i didnt know so i had a diagnostic run for 40 bucks and found out it was my v-tec controller
Old Nov 23, 2002 | 08:35 AM
ithrowpoop's Avatar
Default Re: Check Engine Light? (1slowassr)
my car did the same thing. i checked the codes and it was the map sensor and the vtec presssure switch. the light comes on b/c the car is reading the ecu settings and not the ones you put into the vafc. plug it back in and reset the ecu.
Old Nov 23, 2002 | 08:46 PM
SamC's Avatar
Default Re: Check Engine Light? (ithrowpoop)
thanks guys,
how do you reset the ecu?
Old Nov 24, 2002 | 06:14 AM
stRtypR25's Avatar
can anyone tell me which is the back-up fuse in the fuse box.
Old Nov 24, 2002 | 07:52 AM
ZygSpeed's Avatar
Default Re: Check Engine Light? (stRtypR25)
In the engine compartment, it is the 7.5A Blue fuse (I think).
Old Nov 24, 2002 | 01:03 PM
mstewar's Avatar
undo the negative cable from the battery for a few minutes.. should be reset then..
aspire
Jun 28, 2010 10:49 AM
butter99
15
Dec 18, 2008 04:27 PM
sergei_sh
Mar 13, 2006 06:19 PM
