ITR Strut bar on EK?
I performed the search, but I didn't find any good info on this..
Will a ITR strut bar work on an EK WITHOUT having to drill holes? Or should I invest in a CTR strut bar instead?
Is the CTR strut bar any weaker than the ITR's? Help me out mugz.
My friend has a '01 ITR bar on his '00 Si. It bolted up to the stock studs. But if you dont have an SI you will have to drill out the holes yourself, which should be easy because there are two dimples on each strut tower where the studs should go.
kyden
Oct 9, 2004 04:03 PM
