98+ ITR head on B18c1?
Old Nov 22, 2002 | 03:20 PM
Patrick's Avatar
Default 98+ ITR head on B18c1?
Ok, I was thinking about buying a JDM 98+ ITR head to put on my 95 b18c1, will this head bolt right up with no wiring difference and no clearence problems, and would I see a worth while gain in hp? Also, with my stock bottom end could I take it to 9500 rpm? Thanks for the help.
Old Nov 22, 2002 | 03:22 PM
Patrick's Avatar
Default Re: 98+ ITR head on B18c1? (gsr_vx_hatch)
Does anyone have any good prices on a COMPLETE head (ITM, TB, and sensors) I hate swappin sensors; I had to do it on my mini me.
Old Nov 22, 2002 | 03:36 PM
Evil_Wizard's Avatar
Bump kind of curious about this too.
Old Nov 22, 2002 | 03:38 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
You won`t see any major gains unless you up the compression, too. Drop in R pistons while you have the head off it.
Ryan
Old Nov 22, 2002 | 03:41 PM
eg6sir-s's Avatar
Default Re: 98+ ITR head on B18c1? (vtecvoodoo)
Ryan
also, remember its key to have it tuned right and with proper programming and the right driver. who knows what times you'll make...
[Modified by eg6si, 4:42 PM 11/22/2002]
Old Nov 22, 2002 | 03:46 PM
rainmanEK's Avatar
big strong guy
Default Re: 98+ ITR head on B18c1? (eg6si)
I belive you will still see gains with out the higher compression, though much larger with higher compression!
The ITR head is badass, And the cams will help too!!
Nothing beats factory port and polish
eric
Old Nov 22, 2002 | 03:47 PM
Patrick's Avatar
I dont feel comfortable doing the pistons myself because I have never pulled or installed pistons and dont have the tools to check the cleances. (I would love to do some itr pistons though)
Old Nov 22, 2002 | 04:15 PM
pornstarSR's Avatar
a Type R head is basically a B16 head hand ported a bit.......so yeah you can use it, the cams would help like said before
Old Nov 25, 2002 | 08:48 AM
frankdatank's Avatar
Default Re: 98+ ITR head on B18c1? (pornstarSR)
doesnt the itr head lower the compression?
Old Nov 25, 2002 | 09:05 AM
function83's Avatar
Default Re: 98+ ITR head on B18c1? (hybridcoupe97)
its a straight swap if your worried bout bolting on without modifications.
you can make up for losing compression by using a spoon or mugen thin headgasket.
Old Nov 25, 2002 | 10:01 AM
SPOON_BeIgHtEeNsEe's Avatar
http://tech.hybridgarage.com/tech/headswap/index.html
[Modified by SPOON_BeIgHtEeNsEe, 7:02 PM 11/25/2002]
Old Nov 25, 2002 | 10:51 AM
DOHCtorTHRUST's Avatar
give PROSTREET in hayward a call if you dont want to mess with the pistons...
we took two motors there and got it rebuilt(b18a,b18c1) cleaned and reasembled..
total of 400 dollars... its worth it if you dont want to deal with the hassle of putting it together....
510-723-0001 or http://www.prostreetinline.com
Old Nov 25, 2002 | 11:04 AM
jas0n's Avatar
Please don't hurt me!
Default Re: 98+ ITR head on B18c1? (DOHCtorTHRUST)
u gotta learn 1 way or another
thats why i loving doing stuff myself
Old Nov 26, 2002 | 08:57 AM
Default Re: 98+ ITR head on B18c1? (couter)
true... but if your only daily driver is your weekend worrior, you cant afford to have and KABOOMS or experiment with it...
my buddy put together his bottom end for his ls\vtec by himself and screwed it up... it end up costing him and new bottom end.....not to mention no car to drive...
but thats us...we cant afford a second car...
Old Nov 26, 2002 | 09:07 AM
StageIIIhb98's Avatar
for the money you can spend less and get the itr pistons or ctr which will really increase compr. but if you are going in the bottom do it right or don't do it at all go for true forged piston's and rods and then later you could do what ever you want spray turbo or what ever. You then can really go to 9,500 rpms safer with some head work. That doesn't you will be making true power at that rpm but you could .
JDM JEFFREY
Northwest (Sales)
Oct 1, 2008 10:32 AM
JDM JEFFREY
Oct 1, 2008 10:31 AM
six sigma racing
Aug 12, 2003 01:04 AM
navin
Apr 26, 2003 08:40 PM
strils
Dec 27, 2001 08:02 PM
