Dyno sheet, kind of disapointed.....
Old Nov 22, 2002 | 01:27 PM
ekb18c's Avatar
Default Dyno sheet, kind of disapointed.....
Well here is a pic of my dyno sheet.
I was hoping for 500whp but I guess I will settle for 426whp .
Going back to the dyno to get 500whp.
b18c @ 21psi
plot 1 - 4th gear pull
plot 2 - nailed it 2nd gear
plot 3 - nailed it 2nd gear.
This was on a clayton dyno.
What you guys think???
Here is a larger view of the dyno sheet.
http://www.imagestation.com/mypictur...&id=4244923487
[Modified by ekb18c, 10:45 PM 11/22/2002]
[Modified by ekb18c, 12:02 AM 11/23/2002]
Old Nov 22, 2002 | 01:31 PM
DLB1994's Avatar
Default Re: Dyno sheet, kind of disapointed..... (ekb18c)
car and setup
Old Nov 22, 2002 | 01:36 PM
FredoSP's Avatar
id be happy with 250 whp
Old Nov 22, 2002 | 01:38 PM
b_edson's Avatar
Default Re: Dyno sheet, kind of disapointed..... (FredoSP)
Yeah, I'd be very happy if I had those numbers! What's the setup?
Old Nov 22, 2002 | 01:41 PM
ekb18c's Avatar
Default Re: Dyno sheet, kind of disapointed..... (b_edson)
b18c
10:1 Arias Pistons
62-1
21 psi
[Modified by ekb18c, 10:42 PM 11/22/2002]
Old Nov 22, 2002 | 01:55 PM
FBP Si 2000's Avatar
Me 2.
Old Nov 22, 2002 | 02:00 PM
The Mole's Avatar
Default Re: Dyno sheet, kind of disapointed..... (FBP Si 2000)
tell me that wasnt 12,000 rpm...
chris
Old Nov 22, 2002 | 02:05 PM
ekb18c's Avatar
Default Re: Dyno sheet, kind of disapointed..... (The Mole)
No, hehhe..
the y axis is hp
and the x axis has mph on it.
Old Nov 22, 2002 | 02:21 PM
internet ay's Avatar
this is your street car?? thats sick
Old Nov 22, 2002 | 02:27 PM
ekb18c's Avatar
Default Re: Dyno sheet, kind of disapointed..... (internet ay)
It aint a race car...
Old Nov 22, 2002 | 02:28 PM
Charles B.'s Avatar
hey colin you made that turbo mani. right? it looks really sweet on your motor
btw, nice numbers
Old Nov 22, 2002 | 02:29 PM
D-Man's Avatar
The manifold looks kinda whack,esp where in comes in cylinder #1 but props for something different ...is that a mustang TB?
Old Nov 22, 2002 | 02:33 PM
teamrocket si's Avatar
Awesome numbers. Is that a custom intake mani?
Old Nov 22, 2002 | 02:35 PM
ekb18c's Avatar
Default Re: Dyno sheet, kind of disapointed..... (SuperDuperEG)
Yes, all made in house. The exhaust and intake manifold.
The intake and exhaust manifold may look wierd because we are testing a certain air flow theory on each of them.
edit- yes, mustang TB
[Modified by ekb18c, 11:36 PM 11/22/2002]
Old Nov 22, 2002 | 02:49 PM
newspeedR's Avatar
If you dont mind, where is a Clayton dyno found in the area...
Fuel setup? DFI?...
Im sure you can squeeze the extra Hp out with some tunning...
Old Nov 22, 2002 | 02:52 PM
marty's Avatar
oh wow... colin, get in contact with me via phone or im when you get the chance to. im very proud of you, but you have failed daniel son. 500 is the goal !
Old Nov 22, 2002 | 02:56 PM
b18b25psi's Avatar
ralphy at drt got 460 at 22 psi out of my tegra with a 60-1 and stock b16 head w/2001 itr cams, stock block too
Old Nov 22, 2002 | 02:58 PM
D-Man's Avatar
In house! man you get another could your guys make a similiar exhaust for my D? and how much would it cost,roughly?
Old Nov 22, 2002 | 03:03 PM
ekb18c's Avatar
Default Re: Dyno sheet, kind of disapointed..... (b18b25psi)
I'll get 500whp, Next dyno session coming in a week or so..
but in any event, good numbers. Ralphy is a good tuner .
[Modified by ekb18c, 12:18 AM 11/23/2002]
Old Nov 22, 2002 | 03:32 PM
when do you get full boost with the 62-1?
Old Nov 22, 2002 | 03:45 PM
ekb18c's Avatar
I got full boost @ 6k, but we are still experimenting with the design of the intake and exhuast to make it hit bull boost faster..
Old Nov 22, 2002 | 03:56 PM
jinxproof99's Avatar
New User
i had full boost by 6500 on that 62-1 so your manifold and compression are definetly helping you out a little. wait till you turn it up to 26-27 lbs. you'll be over 500 easy. that thing is made for 28-30 lbs and hits hard as **** on the street. your gonna lose alot of wear on those tires.
Old Nov 22, 2002 | 03:58 PM
Default Re: Dyno sheet, kind of disapointed..... (jinxproof99)
what engine management?
Old Nov 22, 2002 | 04:13 PM
Drew Peacock's Avatar
Is the manifold meant to be equal length or what cylinder 1 and 2 seem to have shorter runner then 3 and 4, was is the idea behind it ...Looks wicked though and nice numbers whats the octane level of the gas your using..
Old Nov 22, 2002 | 04:48 PM
ekb18c's Avatar
Default Re: Dyno sheet, kind of disapointed..... (turbozxi)
This was on c16, for the dyno.
Compression is 10:1 81mm .
I can't wait till I got 83mm.
