replace my 15g greddy?
Old Nov 22, 2002 | 01:00 PM
turbo sol's Avatar
Default replace my 15g greddy?
i know that my top end is not really the greatest. since i have the greddy kit can i buy a 18g from the b16 kit and bolt it into my setup?
Old Nov 22, 2002 | 01:31 PM
UNDER PRESSURE's Avatar
Default Re: replace my 15g greddy? (turbo sol)
Nope, I just called and they said I would have to get the manifold and the TD05H-18G.
Old Nov 22, 2002 | 01:35 PM
TurboSpoolinInside's Avatar
Default Re: replace my 15g greddy? (UNDER PRESSURE)
Hmm.. being a Mitsu turbo, what is the turbine housing on it? a 6cm squared? If so, I would think you could port the manifold to a 7 cm housing, and use a 20g, skip the 18g.
Old Nov 22, 2002 | 05:34 PM
turbo sol's Avatar
Default Re: replace my 15g greddy? (TurboSpoolinInside)
how does anyone feel about this?
Old Nov 23, 2002 | 02:04 AM
I feel you should do it if it is a mitsu exhaust housing...
Old Nov 23, 2002 | 10:07 AM
swrdply400mrelay's Avatar
if you go to http://www.forcedperformance.net/subaru_turbo_fp.htm
you can upgrade. i emailed them and they say it can be done with the greddy 15g. it's an 18T, which flows a little more than the 15g. or you can find a place that can upgrade your turbo to a td04h-16g, which is the turbo that is coming out on the new neon srt-4
Old Nov 25, 2002 | 05:07 PM
turbo sol's Avatar
Default Re: replace my 15g greddy? (swrdply400mrelay)
yes they said they could put in the 18T wheel and clip it for 600 (including the rebuild) I thought that was a little steep. Anyone else?
Old Nov 25, 2002 | 05:54 PM
i'm not sure. other upgrades are just about as much. my biggest question is how much power gains can be expected on top end. also at what rpm boost begins and when it hits full boost. anyone?
Old Nov 25, 2002 | 06:03 PM
turbo sol's Avatar
i think i am going to wait untill the turbo takes a complete crap on me. I am using the stop map sensor so goign over 13-14 psi is the limit for the sensor and the turbo. sounds like i should just stay under that. 12psi daily sounds like a good number to me.
I dont know any specs on what the rebuilt turbo would flow. but he said he does the same work for wrx guys, so i imagine lag would be a bit more than i want.
Sic_DA_Nine
Sep 4, 2008 06:15 PM
Liquidgsr
Oct 31, 2007 08:55 PM
hkeum2001
Aug 24, 2006 04:39 PM
Wo-Nelly
Feb 21, 2004 12:59 PM
