Distributor 92 CX
Old Nov 22, 2002 | 11:47 AM
s13_240sx_92's Avatar
Default Distributor 92 CX
Seems like my distributor will make a noise once in a while like a shreek. But goes away. I had the bearing fail on my prelude so I know what that sounds like and this sounds different. The car is throwing a code, Where is the jumper to read the code in this car? Also where is plug 1(the closest to the timing belt) supposted to be plugged into on the dist. I know the firing order, and the rotor rotates clockwise. An o'clock spec would be great. I'm away from home, reason why I'm asking here and not just looking it up in a manual.
TIA,
BLKHEAP
Old Nov 22, 2002 | 11:50 AM
-Whitey-'s Avatar
Default Re: Distributor 92 CX (s13_240sx_92)
the code jumper is under the kick panel on the passanger side
its easiest to find it if you remove the glove box the jumpers are grey with a green rubber condom thing over them you use the small plug to pull codes
thats all i can help you with
Freemananana
Dec 30, 2013 06:46 AM
Sturg
Aug 17, 2009 08:24 PM
'88civic
Feb 22, 2005 05:06 AM
busychild
Nov 22, 2004 01:58 PM
nevamind
Feb 12, 2004 07:30 AM
