si spark plugs
one more thing to add.. what viscosity oil do you guys use ( for tranny and engine).. i live on the eastcoast and the temp varies with season(durr) .. i was gonna use 5w30 syntec blend just because i have a case of it lying around too. .. i know these are duh questions but i just got this crx and i m just doing routine maintenance before i start driving it daily
I don't know for sure if the plugs will swap, but you can look and find out. Pull a plug from your crx and hold it up to the accord plug--make sure the thread length is the same! Then check the heat range (i believe 7). Then regap if necessary. You can go on the NGK website and get a breakdown of the number/letter code also. As far as the oil--5w-30 should be perfect and syn blend would be a good upgrade to conventional oil.
Johnnyrod310
Jul 8, 2016 07:24 AM
kain9i6
Mar 15, 2012 09:53 AM
GrizzlyMan
Feb 14, 2010 04:23 PM
andrewhill87
Jun 30, 2004 10:51 AM
