need help identifying motor.....
Old Nov 22, 2002 | 11:10 AM
NINJASPY's Avatar
Default need help identifying motor.....
is this a zc or ls? what are the differences?
Old Nov 22, 2002 | 11:11 AM
Hondasaurs's Avatar
Default Re: need help identifying motor..... (NINJASPY)
it is a ZC (1.6l). the valve cover on the LS is slightly longer and the LS is a 1.8l
[Modified by ZC_CRX, 3:12 PM 11/22/2002]
Old Nov 22, 2002 | 11:23 AM
Hondasaurs's Avatar
This is the ZC engine
This is the LS 90-93, notice the difference on the valve cover just bfore the cams? You can tell them apart by this.
Old Nov 22, 2002 | 11:56 AM
Urban Business
Guest
Posts: n/a
Default Re: need help identifying motor..... (ZC_CRX)
this from a teg? its not a zc its a d16a1
zc != d16a1
there is no USDM zc
Old Nov 22, 2002 | 11:58 AM
Urban Business
Guest
Posts: n/a
not a good comparison, 90-93 were b18a's series pre 90 were d16a1s
way different motors
i confuzzled myself yet again
question was it an ls.
yes its an ls d16a1 and not a b series motor
[Modified by TorteX, 3:01 PM 11/22/2002]
Old Nov 22, 2002 | 12:04 PM
Hondasaurs's Avatar
ZC
D16A1, notice the difference in the valve cover bolts and the placement of the Honda symbol
[Modified by ZC_CRX, 4:05 PM 11/22/2002]
Old Nov 22, 2002 | 12:09 PM
Urban Business
Guest
Posts: n/a
block stamps are better
Old Nov 22, 2002 | 12:11 PM
hybrid4dr's Avatar
Default Re: need help identifying motor..... (TorteX)
it's a d series motor a b series ls motor or acura non-vtec motor valve cover bolt and stud nearest to the cam gears (timing belt ) are located in different spots. the B-series motor is like the rest of them u can see the stud it's in the middle of the valve cover at the end the zc i believe has two and they are at the end right next to the timing belt
plus a zc motor is stamped zc on the block the older acura is stamped different
thats the real way to identify it
Hondasaurs's Avatar
True
Old Nov 22, 2002 | 01:26 PM
NINJASPY's Avatar
so that motor IS a zc and NOT a d16a1 or b18?
anyways, here is the link to the car on ebay that I might bid on
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6256
should I bid on it, or should I wait for something else? I was going to get ef si seats or del sol seats... I don't care about the paint, and I will rip the scoop off the hood, or get another hood.
The car already has a zc in it for 1300(current bid), thats a decent price and I am near there so I can pickup easily.
Old Nov 22, 2002 | 01:27 PM
NINJASPY's Avatar
I am just worried about the tranny....
Old Nov 22, 2002 | 01:41 PM
Urban Business
Guest
Posts: n/a
if its a pre 90 teg w/o a swap its a d16a1
zc's are jdm and edm only ther were never in any car we had here
pre 90 teg motors are commonly refered to as zc's even tho they are not technically zcs.
cams, cam gear, stroke are different. not sure about the pistons.
http://community-2.webtv.net/agReziv...siR/page9.html
read all about it
Gummiej
May 19, 2006 01:00 PM
spoon*honda
Oct 11, 2004 03:31 PM
DOHC_EF
13
Jun 4, 2004 09:39 PM
cbstd
May 28, 2004 06:08 PM
