EG ECU wire diagram.......
Old Nov 22, 2002 | 12:19 AM
RICE POLICE SIP's Avatar
Default EG ECU wire diagram.......
I've got a 92 civic hatch and I just got a turbo timer, but a couple of the wires hook up to the ecu wiring.... And i'm not sure which ones they are.... so i need a diagram or pic of which wire is which.. thanks
Old Nov 24, 2002 | 05:28 PM
Default Re: EG ECU wire diagram....... (92boostn'hatch)
does nobody know
Old Nov 24, 2002 | 05:42 PM
Bondel Slo's Avatar
Which ECU wires is the turbo timer looking for?
Old Nov 24, 2002 | 06:02 PM
smackdatass's Avatar
let me guess the apexi one?
Old Nov 25, 2002 | 01:25 AM
Default Re: EG ECU wire diagram....... (Bondel Slo)
It's looking for the 12 volt ignition, 12 volt batt., ground, (pressure sensor,air flow signal) i'm not sure what thoughs are? rpm signal, speed sensor, injector signal... I bought the HKS type 1.... It's supposed to do a lot of diff. things... I can't wait til' it's in.....
Old Dec 4, 2002 | 07:54 PM
does anyone know?
Old Dec 13, 2002 | 04:36 PM
ttt
Old Dec 14, 2002 | 01:26 AM
DelSol808's Avatar
which ecu do you have?
Old Dec 23, 2002 | 01:51 AM
Default Re: EG ECU wire diagram....... (DelSol808)
i have a p28 in there right now... but i might use a p72 also....
EDDIEONETIME
Lighting
Oct 28, 2007 07:38 AM
Weak!EG
Mar 8, 2007 09:01 PM
Sketch_hs
Aug 19, 2004 08:44 AM
