Detailed instructions on how to change brake pads
Old Nov 22, 2002 | 12:10 AM
SRd240sx's Avatar
Default Detailed instructions on how to change brake pads
Does anyone have a "HOW TO" website on how to change brake pads? Specifically on a 98 Civic DX hb with drums in the rear. Pictures would be nice! Your help would be greatly appreciate, thanks
Old Nov 22, 2002 | 11:42 AM
SRd240sx's Avatar
Default Re: Detailed instructions on how to change brake pads (98civichb)
Help!
Old Nov 22, 2002 | 11:43 AM
-Whitey-'s Avatar
so did anyone see the usdm ctr on the roads yet?
Old Nov 22, 2002 | 12:13 PM
greebler's Avatar
Default Re: Detailed instructions on how to change brake pads (B16A EH2)
do your self a favor and go to your local auto parts store and get a Healms manual.
Old Nov 22, 2002 | 12:26 PM
SRd240sx's Avatar
Default Re: Detailed instructions on how to change brake pads (greebler)
They don't sell em at my local auto parts store. They do have the Chilton and Hayes though. Would those happen to have instructions?
Old Nov 22, 2002 | 12:33 PM
Spade's Avatar
Yup.
It's pretty damn simple. All you need is Metric socket and wrench set, and a c-clap to push the brake piston back in before putting in the new pads.
Make sure you open the brake fluid res. to allow over flow when pushing the pistons back into the calipers.
Old Nov 22, 2002 | 04:07 PM
LOwrestling2001's Avatar
Default Re: Detailed instructions on how to change brake pads (Spade)
civic DXs have drum brakes in the rear...so how would u change those?
Old Nov 22, 2002 | 04:55 PM
ArinX's Avatar
Default Re: Detailed instructions on how to change brake pads (LOwrestling2001)
there are some specialty tools involved with changing drum brakes.
Old Nov 22, 2002 | 05:36 PM
hatchback's Avatar
just a correction. its "Helms", didnt want you sounding like a dumbass when you were looking for the manual.
Old Nov 22, 2002 | 08:38 PM
SRd240sx's Avatar
Default Re: Detailed instructions on how to change brake pads (hatchback)
Someone said you just pop the covers off by prying em off with a screwdriver? Is that how you do it? We tried to pry em off but they wouldn't budge.
Old Nov 23, 2002 | 12:26 AM
SRd240sx's Avatar
up
Old Nov 23, 2002 | 03:05 AM
ringerracer's Avatar
Pull Harder
Old Nov 23, 2002 | 03:53 AM
shawnhayes's Avatar
It's a "Haynes" manual as well.
Yes it will have the instructions.
Want my advice?
Get a Haynes, a Chilton, and a Helms. Sometimes the procedures in each are a little different, and sometimes each one has some little "tricks" to help you out. The Haynes manual has better pictures, but the Helms is more complete.
BTW, changing rear drum brake SHOES (on drums they're called SHOES, and when you see them you'll see why) is a PITA the first time. If you have a manual, it will help, but it's not a trivial task.
Shawn
Old Nov 23, 2002 | 07:46 AM
madtownhonda's Avatar
You can press the drum covers off using 2 bolts...I forget the size though
Old Nov 30, 2002 | 09:43 AM
SRd240sx's Avatar
Default Re: Detailed instructions on how to change brake pads (madtownhonda)
Thanks guys...but I think I need more details for the rear drums! NOT THE FRONT!
Old Nov 30, 2002 | 08:58 PM
SRd240sx's Avatar
Someone said there should be 2 screws that you have to loosen to get the drum covers off? I couldn't really find any screws..anyone done this b4 wanna share your thoughts?
Old Dec 2, 2002 | 06:31 AM
CXHatchback's Avatar
I wouldn't even attempt my rear drums cause there are so many springs and stuff to do in the rear. NOT like changing the front pads.
Old Dec 2, 2002 | 06:46 AM
turboD16's Avatar
Default Re: Detailed instructions on how to change brake pads (CXHatchback)
Rear drums are not that hard...theres a small hole on the cover...screw in a 8MM bolt and it pops right off..then undue all the springs and be careful about the wheel cylinder, hook it all up the way it was. If you dont want to get a manual then take one side apart and do it in front of the other wheel so you know what it looks like.
Old Dec 22, 2002 | 08:28 AM
kingpen's Avatar
Default Re: Detailed instructions on how to change brake pads (turboD16)
I just took off the brakes on my friend truck the other day and here is what I did. Tell me if this is correct on a civic too, buecause i need to change mine soon (today)
1. Jacked front of car up
2. Put jack stands under each side
3. Took off front wheels
4. Spun the rotor and held sand paper to it to roughen up the surface. (this step might not be nessecary)
5. Un bolted the top part of the shoe and un bloted the botton, but not all the way.
6. Popped out brake pads.
7. Got a vice like tool and squeezed the piston back in.
8. Pop in brake pads.
9. Bolt shoe back on.
10. Put wheels back on.
11. Let car down.
12. VROOM
Tell me is this is accurate so I can do it to my honda.
Old Dec 22, 2002 | 12:36 PM
ArinX's Avatar
Default Re: Detailed instructions on how to change brake pads (kingpen)
a correct brake job would also require resurfacing the rotors because no matter how striaght they look to your eye. They arent.
my .02
Old Dec 22, 2002 | 02:55 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
I am all for this statement, unless I had a complete break down of the entire process. I would invest in the Helm's manual also.
http://www.helminc.com
dr_spock
Honda Civic (2001 - 2005)
Sep 20, 2008 10:22 PM
Import_spoon
Oct 23, 2006 03:25 PM
R.a.w.
Feb 10, 2006 08:29 PM
dj626
Sep 28, 2004 11:58 AM
