Compression Check--What should it be
Old Apr 19, 2001 | 07:24 PM
Stinkalope's Avatar
New User
Default Compression Check--What should it be
I just did a comp. check on my jdm B16a1 and it was 200psi exactly across the board. It does seem kinda high doesn't it? It looks like the head has been off the car and someone told me it had a gen2 intake. What is everyone's cylinder pressure?
Old Apr 19, 2001 | 07:34 PM
raene's Avatar
Default Re: Compression Check--What should it be (Stinkalope)
Whoa, that IS high... are you sure you did it right? Cranked it over 5 times and all that?? If it's real though, that's DAMN good!
Old Apr 20, 2001 | 08:29 AM
Stinkalope's Avatar
New User
Yeah, thats how I did it. I know it does seem high. I guess that means that my compression has been bumped right?
Old Apr 24, 2001 | 11:53 AM
gambit023's Avatar
just because your b16 reads 200 on the compression test dosn't mean that the actual compression ratio has been changed. your B16 is normal at 200psi. I put new rings in my B16 and the compression went from 190 to 215.
Old Apr 24, 2001 | 09:04 PM
Stinkalope's Avatar
New User
Default Re: Compression Check--What should it be (gambit023)
Thanks for the info......I need to work on my traction problem first anyway before any more mods. I can cruise along in first and roll up to about 5000 and nail it and the car lights em up. I have new springs and struts on order.
EF9_TryMe
Oct 31, 2011 11:12 PM
davidcrx89
Jun 26, 2005 10:52 PM
Capt. Jimbo McSubipants
Feb 21, 2005 12:33 AM
mustbenu
Jan 23, 2004 12:56 PM
Josh717
Apr 20, 2003 08:36 PM
