HELP!! Any mods to put an Si tranny in a DX setup???
Old Nov 21, 2002 | 09:26 PM
dingusjt's Avatar
Default HELP!! Any mods to put an Si tranny in a DX setup???
Alright as you can see i have a d16z6 swap however i've been using my 89 DX tranny, and my car is originally DX, now do i have to modify anything in order to use a 91 Si tranny?
I NEED TO KNOW ASAP BECAUSE IM SUPPOSED TO BUY AN SI TRANNY TOMORROW MORN!!!
Old Nov 21, 2002 | 09:46 PM
Vinceg99's Avatar
Default Re: HELP!! Any mods to put an Si tranny in a DX setup??? (AltezaThug)
there is no difference between the Si trans and the DX trans except for the final drive everything will bolt right up
Old Nov 22, 2002 | 04:23 AM
wannab20hatch's Avatar
Default Re: HELP!! Any mods to put an Si tranny in a DX setup??? (Vinceg99)
What he said.
Old Nov 22, 2002 | 05:20 AM
USDM 4G VTEC's Avatar
second that
Old Nov 22, 2002 | 05:24 AM
EP3_05's Avatar
I will third that....haha
Old Nov 22, 2002 | 05:28 AM
tpr's Avatar
tpr
Default Re: HELP!! Any mods to put an Si tranny in a DX setup??? (wannab20hatch)
You will need to buy the SI clutch as I believe the spline count on the DX and SI are different. The axles will fit no problem. Deffinately do the swap! I had a DX transmission on my '88 DX HB w/ZC and when I switched to the SI box it made a hugh difference in acceleration and top end throttle response.
[Modified by tpr, 2:30 PM 11/22/2002]
Old Nov 22, 2002 | 05:30 AM
EP3_05's Avatar
Default Re: HELP!! Any mods to put an Si tranny in a DX setup??? (tpr)
SI and DX clutches are the same...it is the model year as to where the clutch changes. 88, 89, 90-91 clutches are different.
Old Nov 22, 2002 | 05:59 AM
Default Re: HELP!! Any mods to put an Si tranny in a DX setup??? (91civic)
hes right
88 has 21 spindle count
89-91 has a 20 spindle count
the 90-91 are like 2mm larger clutch surface than the 88-89
keeblar
11
Jan 28, 2025 02:53 PM
Don E
21
Sep 19, 2006 04:36 AM
lshatch1.8
24
Jan 19, 2006 09:39 PM
CrxSi707
May 25, 2004 08:56 AM
serious
14
Jul 17, 2002 03:31 AM
