Ignition timing is working in reverse. How is this possible?
Old Nov 21, 2002 | 05:49 PM
b16awarrior's Avatar
New User
Default Ignition timing is working in reverse. How is this possible?
I have a 91 crx dx with mpfi. I desided it was time to check my ignition timing. Dang!!! How did this happen? When I put the pointer on the timing mark, im nowhere near the red or white marks. they are closer to the firewall of the car. When I rotate my distributor counterclockwise, the car retards. what!? shouldn't it be the other way around? Because when I rotate it clockwise, it moves towards the front of the car, but nowhere near where the marks need to line up. Could I have put my distributor on wrong after the mpfi swap? I know there is the cam key that can only line up one way, but could I have rotated the shaft on the distributor causing it to behave this way? By the way if anyone asks, I did short out the service connector under the dash.
Old Nov 21, 2002 | 05:58 PM
New User
Default Re: Ignition timing is working in reverse. How is this possible? (b16awarrior)
Anyone? Plz I need help, I've done this a thousand times on my b16a on my old Si. This has never happened to me before.
Old Nov 21, 2002 | 07:16 PM
Desslok's Avatar
Make sure the idle is set right for the timing adjustment.
Old Nov 21, 2002 | 07:35 PM
New User
Default Re: Ignition timing is working in reverse. How is this possible? (sp)
Ill, make sure, thanks.
Old Nov 21, 2002 | 08:40 PM
tinkerbell's Avatar
yeah man,
make sure idle is 750rpm +/- 50rpm when setting timing on B16A
t..
flashstar
Aug 18, 2011 12:11 AM
alperx
Engine Management and Tuning
Jun 7, 2011 05:00 AM
91smashbox
Feb 11, 2008 01:33 PM
chris00tt
Oct 11, 2006 12:30 AM
brusk13
Jan 11, 2006 07:01 PM
