b18c wiring harness problems
i want to use the engine harness i recived with the engine and would liek to know if any one has any sites or can fill me in on what all is needed to rewiring the JDM harness for the 98 EK, i already have the ob2-ob1 jumper. so could some one take me from there. thanks
You can't use the harness that came with your motor. The Integra harness is a two piece design. One in the engine bay, one in the cabin..where as the civic is a one piece. The harness wraps around the motor and procedes into the cabin.
The easiest thing to do in your situation is find a 96-98 Ex harness and modify it to fit your motor. There are a few wires that will need to be extended and a couple to to be added. That is 65489456x easier than modifying the GSR/ITR harness that you have.
http://jspectuning.com/6gen
Rusty Shackleferd
Jan 25, 2005 11:28 AM
