ek9 ctr and dc2 itr suspension...
Old Nov 21, 2002 | 02:21 PM
tecnic1's Avatar
Default ek9 ctr and dc2 itr suspension...
how does the ctr and itr suspension differ? are the brakes the same? do the sway bars mount to the same points? and are the parts interchangable? thanks
Old Nov 21, 2002 | 03:52 PM
migs's Avatar
Default Re: ek9 ctr and dc2 itr suspension... (tecnic1)
I know you mount either on either chassis. Some people use the rear JDM ITR suspension and use the CTR front suspension to accomodate the 32mm hub nut.
Old Nov 21, 2002 | 04:59 PM
tecnic1's Avatar
Default Re: ek9 ctr and dc2 itr suspension... (Migs)
with the CTR fronts, do you have to use the 32mm axles? aren't they harder to replace?
and does any one know what size the CTR swaybars are?
Old Nov 21, 2002 | 05:17 PM
Jackson's Avatar
The ctr uses the same size as the usdm models. The jdm itr uses a 36mm axle. The ctr has a 26mm front sway and a 22mm rear sway.
N1_c55
Northern California (Sales)
Apr 19, 2007 11:15 AM
rcurry14
Aug 15, 2004 01:43 PM
jg
Jan 4, 2004 09:02 PM
SargentNg
Dec 3, 2002 12:07 AM
