i'm going sohc VTEC.....
Old Nov 21, 2002 | 10:50 AM
zcivicz's Avatar
Default i'm going sohc VTEC.....
i did a search but i wasn't satisfied so please if you know you're going to post something useless, don't bother! everyone else, please help!
got an 89 dx hb and my co-worker is swapping in a gsr motor in his 95 Si coupe and i told him i'll buy the complete swap for $500 CDN(p28 ECU, tranny, engine) and he agreed. i know i have to convert the fuel system to mpfi but besides that, what else do i gotta do? i mean i know it will drop right in, but i'm not going to use the hydro tranny instead i'll use the 4th gen Si tranny, i wanna use the P28 ECU but if its better or easier to just hook up a vtec switch then i will go that route.
how hard is it to convert to OBD1? do i have to?
i heard someone here sells obd0 to obd1 convertion harness, who is it?? how much?
can i use all the existing plugs to plug right in to...for example...obd1 distro...sensors????
thanks in advance for anyone who helps me.!
Old Nov 21, 2002 | 10:57 AM
red civic standard's Avatar
Default Re: i'm going sohc VTEC..... (zcivicz)
blown90hatch and kenji make OBD0-OBD1 harnesses
maybe we can get a groupbuy goin from blownhatch...he did that one time and had some pretty good prices.
i need a harness and so does my buddy civ616
Old Nov 21, 2002 | 10:59 AM
2camsaam's Avatar
Default Re: i'm going sohc VTEC..... (red civic standard)
Ahh... wise decision.
Old Nov 21, 2002 | 11:01 AM
USDM 4G VTEC's Avatar
k
first just buy off him the ECU and engine.. thats it
get a hold of blownhatch(its not spelled right) and he will sell u the conversion for 170 ish or something...(do a search for OBDO-OBDI conversion)
get a hold of a 4G Si dizzy, injector resistor(only if u stay OBDO), injectorsfrom 4G (only if u stay OBDO), Si tranny,
convert ur car from DPFI to MPFI then use the plug and play conversion... u need to add vtec, oil press, knock sensor, 2 wire O2....
use ur stock engine's mounts!!
u can use the 5G intake manifold.. they work even on ODBO (PM6 bc i am )
any more questions feel free to ask me...
PS, just give him 325 for engine+ecu
[Modified by JDM EF9, 3:03 PM 11/21/2002]
Old Nov 22, 2002 | 05:47 AM
zcivicz's Avatar
Default Re: i'm going sohc VTEC..... (JDM EF9)
well he said he's not going to need the tranny and he doesn't want it lying around his place so i'll take as a favor. i'm gonna ask him again see if he will sell it for just $400 instead of $500 ...the motor gots a lot of kms but still runs mint.
so with the obd0 to obd1 harness, i will need to take out the existing harness and put in the obd1 harness????? isn't that kinda hard to do????
i thought with the convertion harness you don't need to wire in the VTEC? or do you ??
i know the distro is different with 5gs and in order for the 4g distro to work i gotta enlarge the mounting holes and i don't think i wanna do that so i think i'll go the obd1 route........
but will the 4g distro harness plug right in to the 5g distro?????
Old Nov 22, 2002 | 08:34 AM
Flexmyrex's Avatar
if there is a group buy, let me know. im in. thnx
Old Nov 22, 2002 | 10:34 PM
Pengo's Avatar
Default Re: i'm going sohc VTEC..... (flexmyREX)
if theres a group buy on the harness i'm in too
Old Nov 22, 2002 | 10:39 PM
Vinceg99's Avatar
Default Re: i'm going sohc VTEC..... (Pengo)
Well depending on the price I would also be intersted in the group buy....
MugenHonda
Mar 31, 2004 08:05 AM
tmkpres
Sep 5, 2003 10:10 AM
JdM_HoNda
Jul 9, 2003 10:44 AM
TypRice
17
Dec 6, 2002 11:44 AM
ProjectCRXtacy
May 3, 2002 01:17 AM
