sea level times vs. non-sea level times
Old Nov 21, 2002 | 05:51 AM
integranator's Avatar
Default sea level times vs. non-sea level times
how much of a difference are the times in ...ohh say florida compared to the time in ohio-- take the same car for instance running a time in florida, then running a time in ohio- how big of a difference would it be?
Old Nov 21, 2002 | 09:48 AM
SergEK's Avatar
Default Re: sea level times vs. non-sea level times (integranator)
For an exact answer we would need time at sea level (elevation helps) vs elevation at above sea level track.
The NHRA uses a table for elevation I use.
Old Nov 21, 2002 | 10:06 AM
crxHF-R's Avatar
Vegas is at 2400 ft and I run 14.1@98mph ( drag radials )
Sacramento is at sea level I run 13.40's @100mph (slicks)
Lord Quaalard's Avatar
Default Re: sea level times vs. non-sea level times (SergEK)
Here is an equation that is a pretty close approximation of the decrease in ET due to elevation. Multiply the result of this equation by your ET at sea level to see what you would run at a given elevation. Or divide your ET at a given height by the result of this equation to approximate what a sea level run would have been.
Elev Corr = (1-(6.88e-6 * elevation in feet))^5.26
tapesyndrome
Honda Civic (2006 - 2015)
Jan 12, 2010 02:39 PM
Machine1
Jan 17, 2005 01:00 PM
boost fed ls
Apr 12, 2004 04:41 PM
jeremyEG
Jul 2, 2003 10:28 AM
JDM R98
Jul 30, 2001 08:06 PM
