help
I put a 91 crx si motor in my 90 civic std got it finished up last night with the wiring and went to start it up and nothing, I am not getting a spark what does this mean
this is the web sight that I used for the diagram
http://www.zcspeed.com/wiring.htm
but I have seen other sights giving me different pin numbers which is the bes sight to use for the sire up
[Modified by civteg1, 12:28 PM 11/21/2002]
yeah thats lookjs like it
dobble check everything it s good!
i will first check that u are getting fuel... check the spark plugs to see if they are wet. and we know if the MPFI tis working
make sure u GOT the firing order CORRECT
THEN WE GO FROM THERE
[Modified by JDM EF9, 8:49 AM 11/21/2002]
sure the coil is good?? did you put a screw driver in the spark plug wire and crank it next to a ground? if that don't work it could be the icm they usually go bad first befor the coil and every thing else
ok here is the deal coil is good and icm is good, but here is what I have figured out but not sure if I am right, this is the wireing diagram that i used to wire up the engine http://www.zcspeed.com/wiring.htm every other web page that I found does not give you a diagram of the ecu plugs they say to use the chilton manual I looked at the manual and things are different. Here is what's going on the page listed above says to use b15 and 16 which should be empty which they are the other pages say use b10 & b12 but according to chilton there are wires in these pins. Next, page above says to cut wires from c21 and 29 orange and white wire other apges say to use c1 and c2 according to chilton book c1 is orange but c2 is not white it is orange/blue can some please give me the right color for the wires so I can get this thing up and running
So can anyone verify if the website that he is using http://www.zcspeed.com/wiring.htm Is right? This is the one I found and it was in Sport Compact magazine in June of 2002. http://www.4thgenerationcivic.com/ho...conversion.htm Which one is right?? They have differnt info on these pages and the one he is using doesnt match anything I have seen?
I dont know why you cant just click on it?? But you have to copy and paste it.
[Modified by Vinceg99, 12:40 PM 11/26/2002]
check the two white wires in the dist plug coming from the ECU. its possible that you mixed them up cuz they are so similar. the same thing happened to me and i knew right away that i mixed em up so i switched them and the motor started up...try it and see what happens
neophish
Jun 12, 2007 12:00 AM
del_barry
45
Apr 7, 2006 05:07 PM
