What kinda bike for a short fella???
Just like the topic says. I'm a pretty short guy, about 5'4-5'5. I'm kinda sick of the kawi 500 that I have and I think I'm ready to move up to a 600. The only thing is that I don't know what I can fit. I can fit the kawi pretty well. Both of my feet can be placed flat against the ground. What else do you think I can ride?? What about that new CBR 600RR?? You guys think I can ride that???
you can buy ride height adjusters for almost all 600s' to lowwer it to a height that you can touch with both feet on.
[Modified by busa1300, 1:42 PM 11/21/2002]
I was going to suggest the 500 but you're already on it. As for the 6rr, it's a bit higher than the f4i and in my opinion the added height and width would be too much for you. I had a couple 5'5 girls try to ride the f4i and they kept fumbling at low speed. No problems w/ the 500 though. Perhaps look into an f3 and lower the ride height a bit. Don't forget to raise the rearsets up and to the rear for ground clearance and maybe a hi mount exhaust if that has clearance problems after you lower it. I wouldnt' lower it much more than 1.5". Ever consider a naked bike? No plastics, slightly less problem w/ ground clearance and a general lower seat height.
Oh, don't lower the bike. It's gonna screw up the handling. Learn how to ride the bike as it is.
[Modified by Vtec44, 2:40 AM 11/22/2002]
Well basically it changes all the suspension geometry. Also it takes away from your suspension travel and thus requires new bound/rebound settings on the dampers. But the big deal is the rake and castor angles are affected greatly.
I have pretty short legs, but I can firmly plant my feet on my ZX-6E. It's one of the lowest seat-height bikes I've seen. I have to tippy-toe on my buddy's FZR 600.
Dude, that's exactly what the guy at the dealership said. Why is that though?? I was thinking of just lowering it before I talked to him, but he convinced me otherwise and said that it will totally **** up the handling. Dammit, I had my mind set on the 600RR too.
[Modified by Vtec44, 12:43 AM 11/23/2002]
