NGK turbo spark plug Group buy...!!!
hey guys i got a hold of NGK V-power Racing spark plugs..! the ones the Pros use... R5671A-8 and R5671A-9, ... in stock.!! these plugs have and are still used buy , RevHard Mfg, Lisa Kubo, Venom, Dan Shop, and many other pro all motor and pro import cars... if you buy 1-5 sets they will be $1.75 each. and 10-20 set will be $1.50 each anyone interested..??these sell at local race shops for up to $3.50 each.
I am assuming the -8 and -9 are the heat range. 8 and 9 are way too cold for most street setups. Can you verify that those are the heat ranges?
Randy
Randy
Randy
Randy
hmm... if these are good i might consider getting like 2 sets... are 9 too cold for street? cuz kubo runs 3 or 4 x the amount of boost i plan on running.
most of the guys who really know use 8s and 9s... street cars..!! well all the fast ones..!! poeple use 7 and 6 because they either dont know about the 8 and 9s or cus they cant get a hold of the 8s and 9s...!!
8s are too cold for the street...............
25lbs of boost is kind of hard core to run on street. What do you have in your motor?
8s are not too cold..!!at IDRC import team challange nov 23,24 at LACR Palmdale,Team RevHard won the sr1 team challange event.. they are all street driven full body street cars... all are using 9s on the street , all running under 20lbs of boost. im or e mail for payment info...
BCPR7ES-11 is also avail..!! if you are requesting a certain part number let me kno and i will get them for you ...
it doenst hurt to try a bit colder..!! if it doenst work out change it back..!! someday you will need the 8s when you boosting more or on a hot florida day in the summer wont hurt it either..!!
