good bye to my ZC
Old Nov 20, 2002 | 09:48 PM
crashtest Sonny's Avatar
Default good bye to my ZC
ZC is obviously not worth fixing. im gonna finally go b16. i just need some help on it. anything i need to know? before i get the engine? im really clueless on the b16. as far as like.. obd0,1,2? i dont understand what it does ..and about my wiring harness..do i need to get a USDM one..if thre is one? for the motor mounts, which mounts are good? and how much? how bout an intake, i think ill need one, and what would fit? battery? do i need to get a smaller one? or bigger? thanks.
Old Nov 20, 2002 | 10:42 PM
the DR.'s Avatar
Default Re: good bye to my ZC (ridge racer 2)
keep it OBD0, try the one wire vtec thing, hasport, hcp, and plcae racing are good, i think you can use the same intake, same goes for the battery
Old Nov 20, 2002 | 10:43 PM
[626]phixionEF91's Avatar
sonny let me know if your gonna sale your cai
Old Nov 21, 2002 | 05:33 AM
REDBARON's Avatar
Default Re: good bye to my ZC ([626]phixionEF91)
Hey what happened to your ZC?
Old Nov 21, 2002 | 09:42 AM
importfan85's Avatar
Look at the swap tech section of http://www.hasport.com. It's got a lot of info that will be helpful in the swap.
Old Nov 21, 2002 | 10:15 AM
SteveeeO's Avatar
Default Re: good bye to my ZC (4g_civic_si)
what happened to it?
Old Nov 21, 2002 | 10:23 AM
Default Re: good bye to my ZC (SteveeeO)
hmm.i just checked my timing belt and it seem to still be in place. its not snapped or anything. head gasket, little bit of oil leak on the side. but would that cause it to have low compression?
Old Nov 21, 2002 | 10:44 AM
Default Re: good bye to my ZC (importfan85)
hey thanks for the link. it helped a lot also.
Old Nov 21, 2002 | 10:36 PM
can i get a list of what i need and what car it should come from? so i can make a list for myself to estimate of how much to spend. thanks.
Old Nov 21, 2002 | 10:42 PM
-16V-'s Avatar
a 4g_civic_si how did you get your zc pass smog in cali?
[Modified by 1991_jdm_sleeper, 7:58 AM 11/22/2002]
Old Nov 22, 2002 | 08:48 AM
Default Re: good bye to my ZC (1991_jdm_sleeper)
at some smog station paying $200.
SL0-hatch
May 10, 2008 09:04 PM
jcivic33
Jul 27, 2006 10:39 PM
jdmEF8racer
Mar 27, 2006 08:34 PM
TheDR
80
Dec 20, 2005 05:23 AM
91sihatchback
12
Jun 8, 2003 11:05 AM
