Runnin RICH w/ Wideband..
Old Nov 20, 2002 | 03:14 PM
Quick 200k Mile Motor's Avatar
Default Runnin RICH w/ Wideband..
Did a search
can you speak from experience..
Running overly rich at times will ruin a wideband O2 sensor??
Should I replace it yearly?
Old Nov 20, 2002 | 03:18 PM
falcongsr's Avatar
What is this crap?
Default Re: Runnin RICH w/ Wideband.. (Quick 200k Mile Motor)
if you have a wideband, you shouldnt be running overly rich. no?
Old Nov 20, 2002 | 06:54 PM
Default Re: Runnin RICH w/ Wideband.. (falconGSR)
..just for curiousity, the wideband being there and working.
not necessarily hooked up to your EMS for automapping.
For example.. using it for display purposes only.
Running rich like 11.0:1 and sometimes into the 10's.
[Modified by Quick 200k Mile Motor, 10:56 PM 11/20/2002]
Old Nov 22, 2002 | 05:03 PM
up
Old Nov 22, 2002 | 05:06 PM
ekb18c's Avatar
What kind of wideband o2 is it? Is it a bosch or ntk?
ntk sensors have a longer life then the bosch ones.
Old Nov 22, 2002 | 05:20 PM
falcongsr's Avatar
What is this crap?
Default Re: Runnin RICH w/ Wideband.. (ekb18c)
really mine says bosch on the box and ntk on the sensor.
Old Nov 22, 2002 | 05:37 PM
ekb18c's Avatar
really?
You probaly have is Part #: C5010-75044 Brand: BOS Product: Oxygen Sensor OE connector Honda Civic 1.5 VX 3Dr 1992.
It comes in a Bosh box, but is an NTK sensor.
[Modified by ekb18c, 2:42 AM 11/23/2002]
Old Nov 22, 2002 | 05:51 PM
Arturbo's Avatar
Better than steak
25 Year Member
Me too.
Old Nov 22, 2002 | 06:41 PM
LEON's Avatar
Why are you running that rich anyways.
Old Nov 22, 2002 | 07:06 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Runnin RICH w/ Wideband.. (LEON)
If you run to rich youll take out your rings.......
Blaze
Old Nov 22, 2002 | 08:18 PM
shadowdawn's Avatar
Default Re: Runnin RICH w/ Wideband.. (Blaze45)
Last time at the track with my new tech-edge wideband with ntk sensor at boost I ran no higher then 11.3 (mostly 11.1) A/F but it was like 40F outside that day, in the winter I'm running much richer poop on that....
Old Nov 22, 2002 | 08:20 PM
So is my sensor NTK?
Came in black BOSCH box labeled 13246
Old Nov 22, 2002 | 10:16 PM
mos's Avatar
mos
The sensor is NTK. It doesn't matter what the box says.
Old Nov 23, 2002 | 07:05 PM
ladysman's Avatar
Same here.
livedew12
Jan 10, 2012 08:58 PM
Harassing Herbs
Apr 8, 2005 01:35 PM
ATS*Mark
Apr 7, 2004 07:06 AM
ramz7887
Jul 19, 2003 10:48 AM
