Are F22 trannys all the same?
Old Nov 20, 2002 | 08:13 AM
Stew Pidasso's Avatar
Default Are F22 trannys all the same?
I'm looking at a 5-speed tranny for my 94 EX. The one I'm looking at says "THIS UNIT WILL ONLY FIT THE FOLLOWING: Accord '94-95 M.T.; DX and LX" So I'm wondering if there is a difference between the trannys. I'm thinking they're all the same but why would they leave out the EX model?
Old Nov 20, 2002 | 08:44 AM
KGAccord's Avatar
Default Re: Are F22 trannys all the same? (Stew Pidasso)
The trannies of H & F series motors will all bolt-up, but gear ratios are different.
Old Nov 20, 2002 | 08:45 AM
Default Re: Are F22 trannys all the same? (KGAccord)
Thanks, that's what I figured. Anyone know the differences in ratios?
Old Nov 20, 2002 | 10:20 AM
Accord94DX's Avatar
final on the F-series is 4.02 or something and the final on the H series is 4.27 or something
1st and 2nd ratios are the same, 3rd, 4th, and 5th are much closer on the H-series.
Old Nov 20, 2002 | 10:22 AM
carolinaACCORD's Avatar
Default Re: Are F22 trannys all the same? (Accord94DX)
i know nobody cares, but the A/T has 4.13 final.just a little more info.
Old Nov 20, 2002 | 10:27 AM
Accord94DX's Avatar
Default Re: Are F22 trannys all the same? (carolinaACCORD)
dude, nobody cares.
Old Nov 20, 2002 | 10:29 AM
*whimpers* ...nobody likes me....
Old Nov 20, 2002 | 10:38 AM
Accord94DX's Avatar
radioshack does.
Old Nov 20, 2002 | 10:48 AM
SOHCArchangel's Avatar
94 ex has a fd of 4.13, 95 ex has a fd of 4.026
[Modified by SOHCArchangel, 3:06 PM 11/20/2002]
Old Nov 20, 2002 | 11:04 AM
Default Re: Are F22 trannys all the same? (SOHCArchangel)
95 ex has a fd of 4.13, 95 ex has a fd of 4.026
did they make two different ones?
Old Nov 20, 2002 | 11:05 AM
oops, im sorry i mean 94 is 4.13 =D ill go change
Old Nov 21, 2002 | 05:11 AM
What's the difference between the EX and the LX/DX trannys? Which would be better for boost?
Old Nov 21, 2002 | 08:03 AM
Nick M's Avatar
they are all the same d00d 4.062
Old Nov 21, 2002 | 09:55 AM
Conechaser's Avatar
Default Re: Are F22 trannys all the same? (Nick M)
I agree w/ Nick my Helms manual for the '94 Accord says FD is 4.026. Only 5th gen Accord w/ a differ FD is the Wagon, it has a FD of 4.266 (same as h22).
Old Nov 22, 2002 | 02:37 AM
WhoNeedsVtec's Avatar
DX/LX would be better for boost, ex has closer gear ratios then that of the DX/LX.
Old Nov 22, 2002 | 04:47 AM
Default Re: Are F22 trannys all the same? (WhoNeedsVtec)
Thanks
Old Nov 22, 2002 | 10:06 PM
no problem. what turbo setup are you looking to go with?
Old Nov 23, 2002 | 10:25 AM
I'm really still debating... I was dead set on the h22+ turbo but now I'm thinking I may just do my F22. Decisions ,decisions. I guess it really depends on my financial outlook for the new year...
Old Nov 24, 2002 | 04:18 PM
TypeSH's Avatar
where did you get that number? 94 helms says 4.026 (or was it 4.062?)FD for all non-wagons. Only that the EX and Coupe trims had a 0.933 4th gear vs .903 4th for non-ex, non-coupe trims. The other gears are the same among the 94 5-spd coupe/sedans, the wagon had a 4.266 FD (forgot if the other gears are the same thou).
there were many diff F22 tranny's and they had diff gear ratios, 90-93 accords also used f22 tranny's and i think probably have diff ratios as well.
[Modified by TypeSH, 1:23 AM 11/25/2002]
Old Nov 24, 2002 | 04:22 PM
personally i would not swap in the h22, i would find a h23 build it then stick it in with the turbo or just throw it in right away and turbo that....if you short on cash just stick with the f22 and throw the turbo on that, and take the money you saved on building it ...h22 and turbo is just to much work in my eyes.
Old Nov 24, 2002 | 05:58 PM
Nick M's Avatar
Default Re: Are F22 trannys all the same? (TypeSH)
4.13 is the FD of the 4 speed auto.
Joey Mitchell
Apr 29, 2019 07:50 AM
H22Si
Jun 1, 2014 10:05 AM
jdmshawn95
Aug 1, 2010 02:51 PM
IMPORTMyth01
Apr 13, 2005 08:16 PM
NINJASPY
13
Aug 2, 2004 03:26 PM
