JDM frontend, yellow foglight glass broke off! How?!
A piece of yellow foglight glass broke off from JDM housing unit.
I'm so pissed, I had it for two months. Can anyone tell me how it break?
Thanks.
Thanks.
Thanks Reid! The bulb is good. Is there a way to fix it? I think I got to replace the housing, the glass piece look stuck in there.
Thanks again Reid, I hope I get a new housing as replacement. As well for some people in Northern Virginia, Doe anybody got a left non-hid housing for sale? Thanks.
what bulbs are you using for your fogs????
bet it's not the 15watt bulbs your supposed to use.... if you put a "normal" h3 or superwhite the heat ends up cracking the yellow sleeve...and for some reson it's always the left headlamp first....the same thing happened to me.
live and learn i guess
i dont know about 15w.. but the "normal" 55w h3 bulbs work fine. anything HIGHER will crack the yellow glass.
i cracked my left side once as well..had piaa 65w h3 bulbs
since then, i've been running 55w h3 bulbs for over a year now.. no problems!
same here..55w h3..
about the left side? are you talking about driver or passenger side?
I have 1 chrome housing headlight for the driver's side..been waiting forever to get rid of it
[Modified by 98cwtypeR, 11:11 AM 11/20/2002]
It on the left side! Damn, so many of us getting bad luck with jdm frontend.
I"m running on stock 55watt H3, how can I prevent that happening again?
Chrome housing is nice, it remind me of usdm but I prefer black housing.
Thank agains!!
[Modified by CrazyHondaBoy, 7:24 PM 11/20/2002]
Thank agains!!
Hey 98R-1144, how come you have many set of housing? Also the set with no foglights, is that related to foglight cracked? Thanks.
Thank agains!!
Thank agains!!
Is that possible maybe my stock suspension is too rough
causing vibration? Maybe if I put in aftermarket suspension,
it be more smoother and softer instead absorbing vibration
from stock suspension set up. What a good suspension
set up for my car? Name a shock, coilover, it be nice.
Thank everyone for your time to respond.
Appreciate it.
CrazyHondaBoy
Appreciate it.
CrazyHondaBoy
bgood7061
Oct 20, 2002 12:28 AM
