99 civic ex, Need help. Rpms dips occasionally at idle
Old May 7, 2026 | 07:34 PM
Atommid's Avatar
Default 99 civic ex, Need help. Rpms dips occasionally at idle
I have a 99 civic ex with a d16y8. For a little while now anytime im at idle or a stop my rpms will dip occasionally, some days worse than others. I changed the iacv and have no vacuum leaks. Any ideas? Mabe a fuel issue? Injector going bad?
Old May 7, 2026 | 08:07 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 99 civic ex, Need help. Rpms dips occasionally at idle
Dips... as in drops and then comes right back up to the correct idle ?
Old May 7, 2026 | 08:10 PM
Atommid's Avatar
Yes exactly
Old May 7, 2026 | 08:45 PM
Atommid's Avatar
Yes exactly
Old May 8, 2026 | 07:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If the engine hasn't always done this at idle, you likely have a fuel related change. Too little could be caused by lower voltage from the alternator, a clogged fuel filter, weak fuel pump, or even a clogged fuel sock. Too much could be caused by a cracked or leaking exhaust manifold/header or failing O2 sensor. If your fuel economy is really good, you are probably experiencing something caused by the former... if it is unusually poor, it is the latter.
Old May 9, 2026 | 08:57 AM
pimpachu's Avatar
Loved
I have a 96 d16y8, and had similar issues. These issues were fixed after the following repairs, cheapest to most expensive. Distributor cap ( my old one was cracked near a screw). I used a VMS dizzy cap, and rotor costing about $45. You may consider adding a new coil, while you're at it. Grounding wires- three total- battery, transmission, and engine - prices vary from different sources. Due to these prolonged problems, they caused leak in the cylinder head (needs to be machined - my shop charged me $1400). You can check for a leak by putting a no-spill funnel on the radiator and putting a little coolant in it. If you see a repeating blip of air coming out when the engine is running, it's a head leak.
If this helped you, please leave me positive feedback.
Old May 10, 2026 | 04:51 AM
Hadley4's Avatar
It could be a dirty throttle body or FITV issue even if the IACV was changed. I would also check the PCV valve and battery/ground connections since bad grounds can cause idle dips on these cars too.
x4and3r1991
May 31, 2012 06:33 PM
car_mo_na_po
Sep 11, 2011 07:04 PM
XxJohnKampfxX
Feb 15, 2011 04:41 PM
