Replacing Axles in a 1996 RHD Integra Type R
Old Apr 29, 2026 | 10:09 AM
RHD96ITR's Avatar
Default Replacing Axles in a 1996 RHD Integra Type R
Running into issues finding the correct part to replace both driver's side and passenger side axles for my 1996 Integra Type R RHD w/ 4 lug.
Would these be the correct Axles for it based on the research I have found the outers to be a 36MM on these cars. https://insaneshafts.com/product/198...conversion-rh/
PFA:
PFA
Old Apr 29, 2026 | 02:11 PM
Chrisfrom1986's Avatar
Default Re: Replacing Axles in a 1996 RHD Integra Type R
Any stock integra axle will work except the jdm 36mm type r. The hub is 32mm.
Old Apr 29, 2026 | 05:31 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The axle is easily identified by the socket size on the axle nut tightened down on the outside of the hub. If it is 32mm, then you have a standard/smaller sized outer axle spline. If the axle nut is 36mm, it is the JDM ITR/CRV/larger sized outer axle spline. If what you have is the former, then you can purchase axles designed for the USDM '94-01 Integra. If it is the latter, then you will need to source axles that would fit the JDM '98 Spec R Integra.
Old Apr 30, 2026 | 04:59 AM
Buba1's Avatar
You always have the option to swap to the 5 lug USDM and then use the 32mm hubs then any Integra drive shaft would work. Seeing as you have nice 4 lug wheels though, might not be an option for you. I did this conversion myself when I had a '96 spec JDM ITR and was glad I did it afterwards for situations such as this.
Old Apr 30, 2026 | 11:57 AM
They're no point in doing anything you said just to replace axles.
7601chexplicit
Mar 25, 2008 01:44 AM
00R101
Aug 30, 2005 10:45 AM
im_poor
Mar 7, 2003 06:55 AM
TypeRod
Aug 21, 2002 10:48 PM
