Jerking on acceleration and deceleration
Old Apr 27, 2026 | 04:01 AM
RobotechXB9R's Avatar
Default Jerking on acceleration and deceleration
Recently did a lot to refresh the engine on my 98 Civic CX, 5 speed. I've replaced all the sensors, new IACV (twice) and new motor mounts. Replaced head gasket, had head machined for flatness, etc...
Issue I'm having is sometimes, after driving the car for a several miles, it will throw a P0505 code and the car will begin jerking when pressing the gas pedal or releasing the gas pedal. If I clear the code, it acts completely normal. The time it takes for it to start acting up varies greatly. Sometimes I will drive it for 20 miles and never skips a beat, then other times it happens after only a few miles into the drive...I've checked for vacuum leaks, none that I can see even after smoke test.
Any ideas on what to check on next that results in this behavior?
Old Apr 28, 2026 | 04:04 AM
EGproceeding's Avatar
Default Re: Jerking on acceleration and deceleration
If it showed a p0505, which is idle control system malfunction. I would double check the IACV, any vacuum leaks, throttle body cleaning?
Old Apr 29, 2026 | 08:08 AM
pimpachu's Avatar
Loved
I recently had something similar on my d16y8 auto. It was a mixture of 3 things. I needed new grounding wires( one on the transmission, one on the engine). The distributor cap had a hairline crack near one of the screws. AND - just for the sake of completion- the cylinders had a really small leak into the cooling system. You can diagnose a potential cooling leak by putting a no-spill radiator funnel on your radiator and watching for bubbles. I had to get my head resurfaced to fix this issue. Hope that helps.
RC6017
Honda CR-V & Element
May 18, 2022 05:47 AM
khan-civic
Honda Civic (2001 - 2005)
Jul 11, 2013 01:47 AM
goldenmustache
Jun 29, 2009 11:10 PM
phish4709
Jan 12, 2007 07:35 PM
00CIVICwB18C1
Oct 15, 2003 07:22 PM
