96 accord LX 2.2 non vtech crank no start
Old Apr 24, 2026 | 04:03 PM
Myhonda96's Avatar
Default 96 accord LX 2.2 non vtech crank no start
Ok so here's the thing I'm genuinely confused so last week my car died at auto zone I had it jumped got home just fine left and came home again changed the spark plugs and coil pack I had already planned on doing so but when I did that now it cranks but won't start
Old Apr 26, 2026 | 08:00 AM
notsoclose's Avatar
Default Re: 96 accord LX 2.2 non vtech crank no start
Nobody to answer this guy?
OK, I will......If this were my car, I would check for spark and go from there. ---- If no spark is present (probably), then put everything back except the plugs, and see if the engine has spark now. Depending on what you find, you will have several possibilities to a solution. Good luck Sir!
Old Apr 26, 2026 | 02:24 PM
tedmak's Avatar
In the Service Manual, there is a troubleshooting chart for when the car cranks but won't start, if there are no DTC codes. It's in section 11, Fuel and Emissions, subsection Fuel Supply System: System Troubleshooting Guide. You supposed to check 1) Fuel Pump; 2) PGM-FI Main Relay; 3) Injection Resistor and 4) Fuel Filter. I suggest you find the manual, it can be found online.
But in your case since you worked on ignition, I would check ignition first, make sure you have a spark when you crank the engine, there are inline spark checkers which go between the spark plug and the spark plug wire, if there is a spark, the bulb in the ignition checker lights up when you crank the engine.
Like this one, it's only $10.
Amazon Amazon
Old May 6, 2026 | 09:44 AM
Myhonda96's Avatar
Thank I rechecked everything it was my distributor bought a new one and she fired right up
Bryon S
Jan 3, 2024 10:24 PM
Jack Gorlick
Jun 26, 2021 06:11 AM
Jaybird8277
Jul 11, 2020 06:53 AM
96hondaaccord26
Oct 7, 2014 04:50 AM
