Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
04 civic ex limp mode
Old Apr 21, 2026 | 11:58 AM
kings541's Avatar
Default 04 civic ex limp mode
Last year my car has been having issues turning on. Car would crank but no start. I had in mind it was my immobilizer. So I took out the immobilizer chip off my ecu no car is in limp mode. Now does my car need the immobilizer chip to get out of limp mode? Or is it other codes.
Old Apr 21, 2026 | 08:09 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 04 civic ex limp mode
First, check the codes to see if there is something stored that might be causing the poor engine performance. It is likely that you damaged the ECU when you attempted to remove the Immobilizer device inside the ECU. You may have to replace the ECU and have it programmed to match your key and immobilizer ring.
Johnny_em2
Jun 24, 2024 07:52 PM
Ralph Perry
10
May 17, 2021 04:18 AM
gotboosthatch
Apr 5, 2013 10:10 AM
mikewpu04
Honda Civic (2006 - 2015)
Apr 28, 2007 06:59 AM
