Where to go for spark plug replacement?
Hey guys, got another question for all the experts out there. Would you trust a place like Jiffy Lube to replace the spark plugs?
I have a 2002 Accord (4 cylinder). I don't drive that much, but I just realized that I haven't had the spark plugs replaced in ages. I usually do the major stuff (like the timing belt) at the dealer just for peace of mind even though it's more expensive, but I'm not sure if the spark plugs need that type of treatment? Thx in advance!
Spark plug replacement for your ride is straightforward and very easy. A think if that is all that you need, a "Jiffy Lube" place could easily do this for you. The issue is what kind of plugs will they use. You don't need anything special or expensive. Just get the NGK V-power plugs rated for 30K miles. They work great and this is what your car came from the factory with.
Dartanian
May 13, 2006 05:26 AM
