1998 Honda Civic DX coupe Manual
Hi everyone I’ve encountered this issue where my car would turn on instantly and then die, fuel pump will prime check engine light will turn on for 2 seconds and then turns off like normal, it comes back on bc I don’t have my downstream o2 connected but it turned on before even with that issue, I don’t know what to do at this point I’ve disconnected the map sensor the IACV sensor I’ve checked all the fuses none are blown or not giving voltage like they should I have no idea what’s going on
what are your fault codes? I would check the amount of fuel pressure at the rail. It may have a bad fuel pressure regulator or bad fuel filter. This is where I would start. Also check the condition of the cap and rotor on the distributor.
