Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Cost to fix transmission main seal and VVT solenoid leak?
Old Apr 5, 2026 | 08:40 AM
BeeePollen's Avatar
Default Cost to fix transmission main seal and VVT solenoid leak?
I'm looking at a 2010 Civic, and the mechanic says it has 2 small leaks: oil and transmission. They said that the transmission leak could be the "main seal" and the oil leak could be the "VVT solenoid."
1. Do you have any idea what it might/should cost to fix the "transmission main seal"? Mechanic wasn't sure.
2. Do you have any idea what it might/should cost to fix a leak in the "VVT solenoid"?
3. Do y'all have any of your own ideas whether there are any common Honda issues that could cause the leaks?
Thanks in advance for any help!
Old Apr 6, 2026 | 11:22 AM
roddrick's Avatar
Premium Member
5 Year Member
Default Re: Cost to fix transmission main seal and VVT solenoid leak?
Both are common leaks with higher mileage.
dderolph
May 31, 2014 01:04 PM
itzyaboyzeem03
Jul 28, 2008 02:11 PM
grerod3
12
Jul 31, 2004 07:54 PM
96b18c
Jan 24, 2002 06:27 AM
