Coolant spraying on distributor? Where is it coming from
Old Apr 1, 2026 | 05:50 PM
accelelag's Avatar
Default Coolant spraying on distributor? Where is it coming from
on a hot sunny day, stuck in traffic, the temperature goes up to about 3/4ths way for about 5 minutes, before the traffic cleared up and temperature returned to normal.
after competing the drive, I checked the engine bay, and noticed a coolant "splash" mark on the left side of the engine/distributor (first picture)
after another 3 hour drive, I checked the engine bay again, and found more coolant has sprayed onto the engine, coming from maybe the upper radiator hose?
the coolant levels have dropped a bit in the radiator. on top of that, there is this "gurgling" noise coming from the thermostat housing.
further notes about the car: d16y7 - the upper radiator hose is new as I replaced it when I did the head gasket last summer. the thermostat was replaced about a year and a half ago.
my thoughts is the upper radiator hose clamp is not tightened enough from when I replaced it, and some pressure escaped when the hose expanded from the hot summer day! but I would like to hear other thoughts on where the coolant could be coming from
Thanks for reading 😊
Old Apr 1, 2026 | 06:03 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Coolant spraying on distributor? Where is it coming from
My guess would be the heater hose. This hose usually deteriorate faster if oil leaks from the distributor on to it.
Old Apr 1, 2026 | 06:06 PM
accelelag's Avatar
I love your answer because during the winter, I had problems with my heat turning cold whenever nightfall came. I think it could be the heater hose allowing cold air to cool the coolant down before reaching my heater core. Does that sound right to you?
I will also investigate the heater hose tomorrow to notice any cracks.
Thanks for your response! 😊
tony_sol22
Jul 19, 2021 08:10 PM
WaryDriver
26
Jan 8, 2017 09:54 PM
b.ratcliffe11
Sep 5, 2013 09:51 AM
Joseprz
14
Aug 25, 2009 05:05 PM
gohonda
May 20, 2009 08:44 AM
