Need Help Removing ECU Bracket On 1991 Accord
Old Mar 31, 2026 | 12:30 PM
spidersclaw's Avatar
Default Need Help Removing ECU Bracket On 1991 Accord
I'm trying to replace my car's blower motor assembly, and to do this I need to remove my car's ECU bracket. I can't remove it without unplugging the wires leading into what it's housing, though, and I'm at my wit's end trying to get those plugs to come out. What is the intended method? Just pinching the connector and pulling? Is there any more nuance to it than that? Any help would be appreciated.
Old Mar 31, 2026 | 02:32 PM
notsoclose's Avatar
Default Re: Need Help Removing ECU Bracket On 1991 Accord
From what I remember and the bad picture I was able to find.......
Undo the four bolts holding the assembly and loosen it. Reach underneath to "pinch the connector tab" and use the assembly to pull on.
Old Mar 31, 2026 | 02:56 PM
Thank you so much!
CWFL5CTR
Mar 1, 2025 08:04 PM
tinctorus
Nov 7, 2010 12:12 PM
kornkid21792
Jan 16, 2010 05:56 AM
grenthang
Dec 4, 2004 11:33 PM
dahk16
Jun 1, 2004 03:19 PM
