Please help chipped a p75 that works perfectly without the j1 jumper but with it and the chip in it goes into limp mode but the tune is working can anyone he
lp
Are you saying that the chip works perfectly in another socketed ECU ? If it does, then your problem is related to your soldering/socket work within the P75 that you have referenced.
unfortunately I don’t have another socketed ecu to test but I had a base map with the popcorn mod on and that was working which leads me to believe it’s working
