Adapt 3 Button Cruise Switch from RSX/S2000 to 96-00 Civic's With Cruise Control
Old Mar 27, 2026 | 06:08 PM
mimog3's Avatar
10 Year Member
Default Adapt 3 Button Cruise Switch from RSX/S2000 to 96-00 Civic's With Cruise Control
Hey all, hope this helps you all when swapping your wheel from an RSX or AP1/AP2 Steering Wheel Setup with the newer style Cruise Switch.
Connectors needed
IL-AG5-5P-S3C1 Male - https://www.aliexpress.us/item/32568...yAdapt=glo2usa
1 1318620-2 Female - https://www.aliexpress.us/item/32568...yAdapt=glo2usa
It's been a while since I messed with the wiring to initially get it to work. This is a pic i took when i mocked it up 5 years ago. Please let me know if this works for you or if you needed to make any changes as my cruise on my current civic is not working, plan on getting that taken care of. But this did work at the time i did this.
This is what it should look like when you receive it
These are 4 pin connectors but we will only need 3
Make Sure the Green connector that will interface with the Green Connector on the clock spring is pointing up with the small divider, The black connector needs the push tab to be pointing down that will plug into the cruise switch. This is to make sure the orientation is correct and that the wires will be in the correct order.
Pin 1 on the green connector will goto pin 3 on the black connector, Pin 2 on the green connector will goto pin 2 on the black connector, Pin 3 on the green connector will goto pin 1 on the black connector
You can choose to use electrical tape or to wrap up the wires or use heat shrink. I was goin to crimp terminals to make it look better but I'm still struggling with crimping connectors lol.
Old Mar 28, 2026 | 07:36 AM
Heysoos's Avatar
Loved
Community Favorite
Default Re: Adapt 3 Button Cruise Switch from RSX/S2000 to 96-00 Civic's With Cruise Control
I just swapped over the connectors on the boards.
johnlvs2run
59
Nov 7, 2014 11:48 AM
KleinMein
Feb 6, 2013 12:28 PM
eskimo10
Sep 24, 2012 05:48 PM
hotdoggies
Jun 18, 2011 06:28 PM
nurvcom..
Oct 12, 2005 02:59 PM
