1999 Civic Inverted Blink???
Old Mar 25, 2026 | 01:36 PM
Koolstir's Avatar
Default 1999 Civic Inverted Blink???
1999 Civic SI Canadian model
Okay so I’ve got the strangest problem. My right side blinker is blinking faster when the lights are off. Once you turn the lights on, the blink duration becomes very brief with a longer duration between blinks. I’m super confused because both bulbs appear to be working fine.
I couldn’t find anyone with a similar issue, all I found was people with hyperflashing which I wouldn’t say my issue really is.
With the hazards on, everything blinks perfectly normal. I’ve tried switching bulbs from side to side and nothing changed.
My next step is messing with grounds. Does anyone have any advice other than messing around with the grounds? I really think my flasher unit is fine because why would the hazards work perfectly?
Old Mar 25, 2026 | 06:38 PM
roddrick's Avatar
Premium Member
5 Year Member
Default Re: 1999 Civic Inverted Blink???
The combination switch is the issue
Old Mar 25, 2026 | 08:35 PM
Koolstir's Avatar
Can I ask what makes you guess that? Will try to pickup a used one from a wrecker this week then.
Old Apr 6, 2026 | 02:14 PM
roddrick's Avatar
Premium Member
5 Year Member
I've seen this issue before but only a handful of times and the combination switch was the fault. As i remember there was a service bulletin about this issue long ago.
Old Apr 10, 2026 | 07:48 AM
roddrick's Avatar
Premium Member
5 Year Member
Did you resolve this issue?
rawrjaay
Aug 24, 2022 02:38 PM
techsupport
Feb 13, 2017 08:09 AM
GSR936
Dec 7, 2008 01:53 AM
EL Vap133
Apr 16, 2008 09:06 AM
Burnt Orange Teg
Sep 29, 2004 06:51 PM
