Second Opinions Wanted: d16y7 fuel system
Old Mar 24, 2026 | 11:21 PM
</itsjustGreg>'s Avatar
Default Second Opinions Wanted: d16y7 fuel system
Salutations everyone,
I'm considering what other steps/precautions I should take after discovering rust in my fuel tank, primarily in the fuel pump pick-up tray.
• Should I replace the fuel pump and/or clean the fuel lines?
• Has anyone else experienced these problems?
• What did you do to fix them?
• How are things holding up afterwards?
At the moment I will:
• Drain and clean tank
• Replace fuel injectors
• Replace fuel filter
• Stop going to my local Shell station 🫠
Additional info:
This all started when I had a random misfire which I was able to test enough to determine it was caused by the 4th cylinder injector. During that time I replaced the PCV valve, hose, and cleaned the breather box which also had some rust.
The fuel filter had rust in it as well, so from one end point to the other rust is present.
2000 Civic VP (d16y7)
I live in Florida, so it's a very humid environment.
Kind of a long post, so thanks for reading.
Front of fuel tank.
Front of fuel tank.
Front driver side fuel tank pump pick-up tray visible.
Fuel pump strainer
Fuel pump strainer
Fuel pump strainer
Fuel pump strainer
Fuel pump strainer
Fuel pump strainer
Fuel filter with sample of deposits
Ohgodzirra
Welding / Fabrication
Aug 10, 2007 07:43 AM
fracas
Aug 19, 2004 01:58 PM
Evil EG
Apr 4, 2002 09:31 AM
