Unique problems, 95 Accord wagon
Old Mar 19, 2026 | 01:35 PM
Ferbie's Avatar
Default No start when check engine light on.95 Accord wagon
Okay to start, this is my first Honda. I bought it already modified. To the credit to the seller, he told me about the problems and provided receipts for all the work done to the car. The key didn't start the car, had to jump the starter. Wired in a push button start and it works... So long as the check engine light isn't on. I've looped the obd1 wires and it stays solid when cranking, no flashes. Everything I look up brings me to random videos.
https://youtube.com/shorts/038XvPOFrIw?si=OvF9tbeAkaXLy4RY
Video of what's going on.
Old Mar 19, 2026 | 04:03 PM
stas32's Avatar
Default Re: Unique problems, 95 Accord wagon
You said it was able to start when you jump the starter? Or was it just cranking?
Do you have spark? Do you have fuel?
Old Mar 19, 2026 | 05:41 PM
Ferbie's Avatar
It just cranked and cranked. No start.
Old Mar 22, 2026 | 03:39 PM
MAD_MIKE's Avatar
MM Gruppe B
Could be the plastic ignition switch itself is sloppy. They wear out and don't make contact. Turned to II its fine, turned to III it cranks but power to the rest of the ststem drops out.
Does the tach flutter or move when cranking the engine?
That would indicate a problem.
Old Mar 23, 2026 | 08:50 AM
Ferbie's Avatar
No. The tach doesn't move. Me and my cousin are considering getting another ECU or having this one flashed and anti theft disabled.
Old Mar 23, 2026 | 09:04 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Stock 1995 Accords didn't have the Immobilizer (anti-theft) system.
Old Mar 23, 2026 | 10:21 AM
Ferbie's Avatar
So it sounds like it's my ECU... Goody...
Old Mar 23, 2026 | 10:31 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Not necessarily the ECU. It still can be due to other things.
Old Mar 23, 2026 | 10:53 AM
theYBLEGAL's Avatar
Loved
To me, sounds like the wiring at the ignition switch is messed up. Besides cranking, the key needs to complete the ON circuit, or you need to jump those wires to power up the ECU and supply power to the fuel pump and ignition relays. If you aren't powering up the ECU and those relays, it will still crank but you won't get fuel or spark or a running engine.
Old Mar 23, 2026 | 11:13 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Yes, it may be the wiring is messed up to the main relay or ECU; or faulty ECU; or faulty main relay.
From your youtube video, it seems there is no fuel.
What theYBLEGAL said is on point to complete the start circuit.
The following is link from the Wayback Machine regarding how the Main Relay circuit works.
https://web.archive.org/web/20080605...ion/index.html
Old Mar 23, 2026 | 11:20 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Normally,during start, power goes to the ECU and Main Relay; the Check Engine Light will come on and go off; ground is sent from the ECU to the Main Relay. The fuel pump will then get power after that.
Old Mar 23, 2026 | 01:57 PM
Ferbie's Avatar
I've resoldered the main relay. Checked the ignition wires entirely (they're good), and pretty much did everything y'all are suggesting. It all goes back to the same, ECU is having issues. The following is what happens
Key in ignition. Turn key to II. Check engine light comes on. Fuel pump kicks on. Check engine light stays on. Press button. Engine cranks but doesn't fire. Leave key at II for 10 ish minutes. Check engine light goes off. Press start button. Car starts.
Old Mar 23, 2026 | 04:24 PM
theYBLEGAL's Avatar
Loved
Hmm. In that case, it might be ecu related. Inside the ecu, check the condition of the capacitors. If they are leaking, replace with same spec caps. There is also an integrated circuit, IC17 responsible for regulating voltage. That can cause fuel pump prime issues and a slow-to-turn-off check engine light. Check that. Google searching P28 IC17 repair will get you plenty of info
Imo, 'retail' refurb ecus are overpriced. Used oem ecus are a dice roll. Do your best to fix yours. Since you can solder. Caps are cheap. IC17 is cheap off ebay usually.
Old Mar 23, 2026 | 08:39 PM
MAD_MIKE's Avatar
MM Gruppe B
Have you replaced the ignition switch?
They wear out and cause all sorts of electrical issues.
Its ~$20 from rockauto.
Old Mar 24, 2026 | 03:07 PM
roddrick's Avatar
Premium Member
5 Year Member
Did you resolve this issue?
Old Mar 25, 2026 | 09:42 AM
Ferbie's Avatar
I think I should have clarified, had it soldered. I know the basics of how disorder but this was something I had to take to somebody who knew more.
As for the ECU, me and my cousin said screw it and ordered one from Georgia, about 5 hours away from us. Waiting on it to show up now. And since we're waiting we have decided to do the rear main seal because it leaks from there. Only problem we are having right now is that one of the sensors doesn't have a way to pull it apart.
Old Mar 25, 2026 | 09:44 AM
Ferbie's Avatar
No clue what this sensor is called, help please.
Old Mar 25, 2026 | 02:37 PM
MAD_MIKE's Avatar
MM Gruppe B
Looks like reverse light switch.
Follow the harness, there will be a couple of bullet connectors. Not typical plastic connector.
When installing the new RMS, a pvc sewer pipe coupler is the perfect size.
Old Mar 25, 2026 | 03:08 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Old Mar 25, 2026 | 06:14 PM
Ferbie's Avatar
Out of everything, I didn't even think of that...
Old Apr 3, 2026 | 08:52 AM
Ferbie's Avatar
Okay. So... I'm an idiot. The ECU is just the wrong one all together. It'll run and drive just fine but I'm back to square one. By chance does anyone happen to know the factory ECU part number for a f22b2 with a manual trans? Because Google is giving me several different numbers and my brain hurts...
Old Apr 3, 2026 | 12:05 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
37820-P0J-A10
Old Apr 3, 2026 | 12:39 PM
Ferbie's Avatar
Originally Posted by tech8
37820-P0J-A10
I call shenanigans... But. F*(/ it. If check engine light comes on I'll just turn the key to on and wait 10 minutes. Because for some reason whatsoever that works. Ish.
Old Apr 7, 2026 | 06:23 PM
Ferbie's Avatar
37820-P0B-A01 is what Google tells me. So... No clue what to do here.
Old Apr 7, 2026 | 06:41 PM
Ferbie's Avatar
