Honda Accord 2018- Current This is the place to discuss all things Honda Accord related for the 2018- Current model year
B1237 AMD(As) motor Potentiometer Shorted - HVAC
Old Mar 7, 2026 | 04:07 PM
PhilipS's Avatar
10 Year Member
Default B1237 AMD(As) motor Potentiometer Shorted - HVAC
2020 Accord.
OBD scanner found this: B1237 AMD(As) motor Potentiometer Shorted
Not experiencing an issue right now. May have to remove the glove box to see all the motor solenoids in action. Passenger temp control wiorking fine.
Couple years ago I had a B1220 and replaced the Fresh air Blend door motor ([size=13px]79351-TVE-H01)[/size]. The telltale was that the Recirc LED did not illuminate. Removed the HVAC to get the motor back into place; not hard.
What else am I to be looking for and any system tests to run? Auto A/C seems to be functioning fine. Doesn’t seem like there's a wire harness or module issue. Thank you in advance.
Old Mar 10, 2026 | 02:27 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: B1237 AMD(As) motor Potentiometer Shorted - HVAC
Id clear the code and ignore it,if there are no issues.
If the code returns, you're very likely looking at a failing passenger air mix motor.
There are no printed service manuals, you'd need to buy a subscription if you're interested in trouble shooting steps:
https://honda-tech.com/forums/tech-m...-link-3330938/
Old Mar 11, 2026 | 07:21 PM
PhilipS's Avatar
10 Year Member
Thanks. It was a cold morning 48F on the dark desert highway.
Passenger side blows cold unless pass temp forced on high temp; with recirc off.
A/c temp variation not noticed between sides.
This motor is accessible by removing the glove box? 79170-TEX-Y61 presuming the potentiometer is inside the motor?
Lezli1946
Dec 19, 2020 01:04 AM
ggcostelloe
Nov 14, 2017 07:26 PM
VRD^don
Dec 24, 2004 07:40 PM
daidilus
Dec 10, 2004 04:16 PM
