I have a 2000 civic lx it has the drum brakes with metal tubes. I was curious if there is a replacement for the tube for a actually brake line. One of the tubes is rusted and squirts fluid. I saw there's the main line replacement ...I was just curious about the tube.
You could buy some straight brake line then bend and flare it yourself. It looks like a pretty aggressive bend, so you're going to be lucky if you can do it without kinking the line. After you spend the money buying the right tools, you're probably even (or over) what it would cost to find an old mechanic to do it for you.
Only other option I can think of would be swapping to disc brakes as you stated.
