1992 Civic DX Hatch with B20z2 swap needs AC
Old Mar 3, 2026 | 04:24 PM
jigglebop's Avatar
Icon3 1992 Civic DX Hatch with B20z2 swap needs AC
Anyone with a 1992-95 DX Hatch with a B20z2 (came out of a CRV) put AC in the car. What can I use from the EG and what can I use from the CRV, I can find these things everywhere at the junkyards.
I would love some insight from your smart Honda folks if you are willing!
Old Mar 3, 2026 | 07:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 1992 Civic DX Hatch with B20z2 swap needs AC
You can use everything from the Civic AND the original CRV A/C bracket if your engine came with one... if not, you can find either a P30 (Del Sol DOHC VTEC) or P7J (CRV) A/C bracket and tensioner and bolt your Civic A/C compressor to it.
Old Mar 4, 2026 | 02:03 PM
jigglebop's Avatar
Very helpful, thank you! Would you know if the wiring harness + the ECU would of been swapped as well if they put the B20z2 in the car?
If so would this effect anything with the AC install?
Old Mar 4, 2026 | 08:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Neither the engine harness nor the ECU from the CRV can be used in the '92 Civic chassis. If I was doing your swap, I would use the engine harness and fuel injectors from your original engine. Modify the wiring harness as needed to reach all of the common sensors, source a '94-95 Integra LS/RS/GS distributor and manual ECU, modify the ECU to accept a Hondata S300, and have the engine professionally tuned. Others here may jump in and bash the S300 system as a bad choice... and suggest another engine management solution like a Link ECU or other stand alone box... the important part to understand here is that no factory ECU works ideally with your combination, so a tunable solution is necessary.
Trytoslayer
Jun 15, 2021 09:08 AM
Racer-X
Honda Civic (2006 - 2015)
15
Jul 5, 2006 11:05 AM
piatl7il77
Dec 28, 2005 11:09 PM
hondaZvic
36
Jun 16, 2005 10:04 PM
