Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Door alarm chime fell down inside
Old Feb 8, 2026 | 09:33 AM
debodun's Avatar
5 Year Member
Default Door alarm chime fell down inside
You know, the little rubbery button that makes a chime when the keys are left in the ignition or the lights are on when opening the driver's door.
What would be a reasonable price to have it put back in place?
Old Feb 8, 2026 | 10:04 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Door alarm chime fell down inside
The door jamb switch part price is around $12. It is just held on with a Philips screw. The switch can literally be replaced in a couple of minutes as long the the wire connector didn't fall inside the door jamb.
If the wire connector for the switch fell inside the door jamb, the hard part is to fish out the wire. Use a cost hanger making a small hook to try to fish it out.
Old Feb 8, 2026 | 10:33 AM
debodun's Avatar
5 Year Member
When it first happened, I took it to a general service garage. They tried to retrieve the connectors which had also disappeared, but I think they only succeeded in pushing it further down inside.
Old Feb 8, 2026 | 11:02 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The connector is part of the floor wire harness.
If a shop can't fish out the wire connector from the front, they can try taking off the interior plastic B pillar lower cover off to get at it. This YouTube video shows the removal of the plastic cover. Since side impact sensors, etc. are located near here, the negative battery cable should be disconnected and waiting at least 3 minutes before starting any work.
prmora
Oct 28, 2021 08:25 AM
CTRwannaB
Audio / Security / Video
May 13, 2006 04:33 PM
