99 honda civic ex. Fuel pump fuse has no power!
Old Jan 22, 2026 | 01:05 PM
McAwEsOmE's Avatar
Default 99 honda civic ex. Fuel pump fuse has no power!
So my honda was running fine then one day just stopped. Changed the fuel pump thinking it was because it needed to be changed. Try to start and no go. Checked the fuse it works just fine. Used a voltage meter to find out there was no power coming from the fuel pump fuse port... can anyone tell me what I need to do. I wanna keep my honda.
Old Jan 22, 2026 | 06:04 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 99 honda civic ex. Fuel pump fuse has no power!
you have a burnt fuse. How did you check them.?? I've see some "good-looking" fuse end up being bad. Always use a multimeter to check for continuity.
Old Jan 22, 2026 | 07:15 PM
McAwEsOmE's Avatar
Yes my brother inlaw did. And he checked both the fuse and the fuse port with his multi meter and the port for the fuel pump fuse had no voltage. Plus the voltage on some of the other fuse ports where throwing low voltage readings. I should have included that also when I was asking my bad.
Old Jan 23, 2026 | 02:45 PM
NVturbo's Avatar
O.G. triple O.G.
the PGMFI relay may be bad.
Old Jan 26, 2026 | 05:17 AM
MK99's Avatar
Mine turned out to be the main relay. I turn on my ignition and tap the main relay then I hear my fuel pump priming. main relay is on the passenger side.
Old Jan 27, 2026 | 04:14 AM
speedooo's Avatar
Sounds like the main relay.
Old Jan 29, 2026 | 02:46 PM
McAwEsOmE's Avatar
So update. The fuse box isnt putting out power to half of the things in the car. So now im wondering if its my fuse box or the wiring harness. But I can seem to find a proper wiring diagram or fuse panel diagram anywhere. Does any one know where I can find them for free?. So we can look at it better n find the actual source of the problem.
Tyler Ketron
18
Dec 28, 2019 05:06 PM
Cordell Raw
Apr 20, 2016 01:23 PM
frameguy
Oct 2, 2015 01:47 PM
Frost7177
Apr 30, 2007 03:26 PM
